Modified 350
May 05, 2016, 08:45:16 pm
Author Topic: Hub spacers  (Read 536 times)
AgentX
Hub spacers
« on: January 29, 2013, 09:24:59 am »
I'm installing a current model disc fork on my old iron barrel.
What's the proper arrangement of spacers on the axle?
From Hitchcock's diagram, from driver's right side, it seems it's fork leg, speedo drive directly against the fork leg, cylindrical spacer between the speedo and the hub bearing, hub, stepped bushing, left fork leg.
Correct?
motomataya
Re: Hub spacers
« Reply #1 on: January 29, 2013, 10:32:50 am »
Correct.
AgentX
Re: Hub spacers
« Reply #2 on: January 29, 2013, 06:29:56 pm »
Thanks!  There are, um, a variety of creative methods I've seen used here in India.
