Royal Enfileld AVL
May 03, 2016, 03:10:47 pm
Author Topic: Seeking Rear Wheel Alignment Shortcut  (Read 2733 times)
jartist
Re: Seeking Rear Wheel Alignment Shortcut
« Reply #15 on: January 26, 2013, 11:08:47 am »
Are there any problems with checking the alignment on the right side while the bike is on it's sidestand?
« Reply #16 on: January 26, 2013, 11:11:28 am »
You need to check both sides at the same time with the bike upright.  Get a rear stand, have someone sit on it, or work around the center stand.
« Reply #17 on: January 26, 2013, 11:40:15 am »
I have just one lazer pointer just like in the pic..Nice jig he made to line up the front/ rear..Maybe I'll make one if I have the scrap...
squire
« Reply #18 on: January 27, 2013, 12:11:11 am »
I've always used two aluminum straight edges.
« Reply #19 on: January 28, 2013, 09:02:18 am »
1. gravity may distort your stick
2. differing tire pressures and tire types will influence sidewall flex
2002 BMW R1150RT-P
