Interceptor
April 29, 2016, 04:46:19 pm
Author Topic: Front sprocket, same as the old 5 speeds?  (Read 723 times)
« on: January 20, 2013, 11:28:49 pm »
I went to the dealer to get a set of sprockets for my 2010 C5 the other day.  $75 for the rear, kinda sounds right.  $60 for the front.  What?!?!?  He felt the same way, sounded like a lot.  He was going to check and get back to me.
So I poked into NField Gear and saw this:
http://nfieldgear.com/enfield-store/maintenance-repair/driveline/5-speed-countershaft-sprockets.html
$34 sounds better than $60.  It looks like the right part.  Anyone know for sure?
Thanks,
GlennF
Re: Front sprocket, same as the old 5 speeds?
« Reply #1 on: January 21, 2013, 12:04:45 am »
Pretty sure that is a no. But only becasue they seem to pop up as separate items in parts catalogs. I have not actually sat down and compared the two to see what the difference is.
« Reply #2 on: January 21, 2013, 12:22:09 am »
I think you're right.  Hitchcocks has them listed separately under different part numbers.
« Reply #3 on: January 21, 2013, 04:36:17 am »
I'm upgrading my B5 to an o-ring chain - Tim at NFG sold me a "FD sprocket 18T (UCE)" - NFG part #571032.  $39.99.
motomataya
« Reply #4 on: January 21, 2013, 09:03:23 am »
The hole is a larger diameter on the old 5 speed.
« Reply #5 on: January 21, 2013, 10:08:31 am »
Thanks to both of you.  I can see the dealer marking up parts a bit but 50% would be a bit stiff.
