Bullet
February 11, 2016, 11:15:34 am
Author Topic: Update: C5 "vibration isolating" footpegs  (Read 1313 times)
GSS
« on: January 20, 2013, 06:40:46 pm »
I had been looking at these at Nfieldgear.com and bought a set to try on the C5. Fit and finish was basically outstanding. Went on easy and look great.
First photo shows the parts. Only parts not included in the package were pins for the hinge point.  I bought a couple of 5/8" clevis pins for a dollar at a local hardware store and was all set.  Photos 2 and 3 show it open and folded in.
GSS
« Last Edit: May 26, 2013, 11:26:38 pm by GSS »
2014 GT - Red
2010 C5 - Teal
It's a Jeep thing......
FiRE Comms
  • '11 C5
Re: C5 "vibration reduction" footpegs
« Reply #1 on: January 20, 2013, 06:44:47 pm »
those look great, glad to hear it was an easy job...
Chris
Re: C5 "vibration isolating" footpegs
« Reply #2 on: January 20, 2013, 10:36:36 pm »
Nice job, good to know they fit the C5.  BTW, if the rubber bits wear out or you just want to change things up check out Kuryakyn.  They make the footpegs and replacement parts.  Andy any of these pegs can also be mounted up without much trouble.  Lots of Harley shops carry these if you want a look.
http://www.kuryakyn.com/Metric/Foot-Controls/Foot-Pegs
« Last Edit: January 20, 2013, 10:38:59 pm by Ducati Scotty »
greekxj
« Reply #3 on: January 21, 2013, 08:19:54 am »
Very cool, i have them on my 07 iron lung. I had them as takeoffs from an old cruiser i used to have. I also had the mounts from the old bike too. I modified the mounts a bit with some grinding so they would allow the mount to line up with the bolt hole in the bracket from the bike. Mounted them up and they look and work great. They dont pivot but its ok.
GSS
« Reply #4 on: January 21, 2013, 05:51:32 pm »
Thanks.  I did look at HD stores and Kuryakyn catalogs but the missing piece was always the RE specific mount.  The CMW kit came with a mount that is basically a shortened stock RE mount with a nicely engineered "U" into which the Kuryakyn peg fits perfectly.
I had also picked up a 1.5" peg extension kit not knowing how much tinkering this would require, but there was no need for that......I am sure I will find some other project for the extension tubes!
2014 GT - Red
2010 C5 - Teal
motorat
« Reply #5 on: January 21, 2013, 06:02:18 pm »
nice.
that is something i will get as i have hit the pegs several times riding ad really like the folding peg better.
Joe
08 dl650abs
 c5 military
sparklow
« Reply #6 on: January 21, 2013, 07:44:39 pm »
I'd love a set of these. The rigid mounted foot pegs are not the Enfields finest feature. Do you know if they fit a B5?
2011 B5
GSS
« Reply #7 on: January 21, 2013, 08:07:41 pm »
They probably do. Most parts like these are pretty much the same across all RE models.
2014 GT - Red
2010 C5 - Teal
GSS
« Reply #8 on: May 26, 2013, 11:16:10 pm »
Update: finally got over winter in tropical Minnesota and went out for a brief spin.  I had almost no vibrations with the stock footpegs, but the new one led to a dramatic increase in foot numbing vibrations.  I am pretty sure that the looseness in the hinged part of these footpegs is what is making the vibrations worse.  These have been taken off for now......they sure looked nice......
2014 GT - Red
2010 C5 - Teal
BRADEY
Re: Update: C5 "vibration isolating" footpegs
« Reply #9 on: May 27, 2013, 12:08:56 am »
Hi GSS, thanks for sharing this.
May I know, how do the new foot pegs
lineup with the gear shifter and brake lever.
I mean are these a bit lower (it seems from the picture)
or exactly in teh same position as the OEM.
If lower, will this affect ground clearance on turns/banks ??
GSS
« Reply #10 on: May 27, 2013, 08:41:43 am »
The mounting position and location relative to shifter and brake is identical to the stock feetpegs. It would have been perfect if it wasn't for the increased vibration. It might be worthwhile to lock down the folding part to see if it reduces the vibration..... Maybe JB weld in the hinge, but then all you gain is an expensive nice looking footpeg.
2014 GT - Red
2010 C5 - Teal
Royalista
  • phaneropter
« Reply #11 on: May 27, 2013, 05:37:48 pm »
I was in the market for folding pegs, had some reservations and was looking for a clear image of them.
The pictures clarify it all. Thanks for putting them up.
I had hoped they'd fold upwards. That would've been better.
Could perhaps even avoid those vibrations?
Sorry they didn't work out for you.
moriunt omnes pauci vivunt
