D-Day Commemorations 2009
32 Guests, 4 Users
cafeman, Narada, Ice, BeezrGeezr
May 25, 2016, 11:46:19 pm
Author Topic: Mussette saddle bag actual dimensions  (Read 920 times)
Ex Zurin
« on: January 15, 2013, 01:38:58 pm »
I know some of you are using the Mussette style saddlebags on your bikes.  I have seen these advertised with dimensions given as being 12 x 12 x 6 inches.  I like the style of the bags however I was thinking of using some plastic file folder boxes as inserts in them but the closest ones that I can find dimension wise actually measure 13-3/8 x 6-3/4 x 11-3/4 inches.  The 13-3/8 width occurs at the top inch or so of the box with the bottom portion measuring approximately 12 inches wide.  I have attached a photograph of the boxes that I was looking at.
My thoughts were that if these could be inserted into the bags that they would provide a weather proof enclosure and with the integrated handles in the lids, they could be easily removed.  Heck with them being plastic one could fill them with ice and 'beverages' if one is so inclined.
Anyone care to post actual dimensions of their similar styled bags?
Re: Mussette saddle bag actual dimensions
« Reply #1 on: January 15, 2013, 03:20:30 pm »
    I've got the canvas mussette bags on my '08 Classic.
    They're 12" high, 11" wide & 6" deep. The top flap & straps will close over something higher than12".
     (That huge muffler is long gone).
« Last Edit: January 15, 2013, 03:23:03 pm by tooseevee »
2008 ACE Head AVL Classic
Royalista
  • phaneropter
« Reply #2 on: January 15, 2013, 03:57:14 pm »
Dimensions of my bags are W17" H12.5" D5"
Heavy duty canvas, brass fittings, straps galore, pockets front & aft for stuff requiring fast access.
moriunt omnes pauci vivunt
Bulletman
  • 2011 - C5 Classic Black
« Reply #3 on: January 16, 2013, 10:04:05 pm »
Hi Ex, I have the same musette Bags for my bike, be warned that the bags have different dimensions although they are made by the same manufacture, I basically used styrene from 'Tap Plastics " a local California plastics shop. I measured the internal dimensions of the bags & had them cut to size. I now  have a great set of bags.
Cheers
Mark
"A Blast from my Past"
Mark F   (Northern, CA)
Black C5 2011
The_Rigger
« Reply #4 on: January 19, 2013, 12:20:14 pm »
Are these the "Fox Musette Bags" that Amazon sells for around $12-15?
-Dave
2012 C5 Special
« Reply #5 on: January 19, 2013, 12:38:45 pm »
         Yes. I got mine from an Army/Navy store. $11.00
Bulletman
« Reply #6 on: January 19, 2013, 12:59:03 pm »
Yup! I got mine from the Amazon store.
Black C5 2011
