Harris Clubman
41 Guests, 9 Users (2 Hidden)
BeezrGeezr, flyman, Arizoni, wfrpalm, rollingyogi, cafeman, krimp
May 25, 2016, 05:53:01 pm
Author Topic: Royal Enfield rear wheel easy to remove  (Read 2097 times)
stevejohnson
« on: January 09, 2013, 08:48:39 am »
The owner's manual of my 1999 Bullet helpfully suggests that you tip the motorcycle over on its center stand and fish the wheel out from under the fender and muffler. I've done that. It's no fun. :D
Regards
Steve Johnson
cheapviagramedics
Re: Royal Enfield rear wheel easy to remove
« Reply #1 on: January 09, 2013, 12:22:25 pm »
Unbolt the fender and lift it up slides right out.  ERC
« Reply #2 on: January 09, 2013, 03:34:17 pm »
Regards
Steve Johnson
cheapviagramedics
The muffler is only on 1 side. The other side is wide open. I'd tip the bike and kick the wheel out 20 times before I'd waste my time to unbolt the fender.
« Reply #3 on: January 09, 2013, 05:22:14 pm »
even easier if you rock it on the centerstand onto a
2 x 4.  less than a 10 minute job once learn the tricks...
« Reply #4 on: January 15, 2013, 01:03:58 pm »
If you have the early B5-Style frame. take the two bolts put of the front of the fender braces and the fender will hinge up to allow the removal of the wheel.
mikail gransee
« Reply #5 on: January 16, 2013, 05:30:15 pm »
That is the best...BUT when youput it back on make sure to line it up and torque proper or problems may arise.   ;)
-"ONCE YOU STOP CONTRIBUTING, YOU BEGIN TO DIE",   -ELENOR ROOSEVELT
1999 Enfield Bullet
1977 Yamaha xs360 TD
1978 Yamaha xs 400 D
2005 Yamaha YZF 600R
2007 Honda CBR 1000RR
« Reply #6 on: January 16, 2013, 07:52:34 pm »
If you can find a strategic drop in the surface you're putting the bike on (say, a curb or a where a steep driveway begins to slope down) and back the bike up to it, the wheel will come right out.
A short length of 2x4ish wood is also a good thing to carry on long trips.
boggy
  • Karma Ultra: 7
« Reply #7 on: January 17, 2013, 03:14:54 pm »
David Blasco has you covered with this "easy to do" rear wheel removal instruction video.
http://www.youtube.com/watch?v=3KkOgpuAQDU
Good stuff.
2007 AVL
2006 DRZ400SM
« Reply #8 on: January 18, 2013, 12:04:17 pm »
Good Vid but only "cute" if you've got a solo seat...
    otherwise long seat will need removed as well.
              - Mike
Royalista
  • phaneropter
« Reply #9 on: January 18, 2013, 04:32:52 pm »
              - Mike
in which case it is much handier and faster to rock the bike and slip the wheel out from the side. Especially if you also have the brackets for saddlebags removal of seat is a tedious process.
Anyway the tip is not in my owner's manual. Possibly C5 only?
moriunt omnes pauci vivunt
