Fall is coming
February 12, 2016, 08:31:25 pm
Author Topic: Sliiping Sound  (Read 1391 times)
blaisecardoz
Sliiping Sound
« on: January 03, 2013, 10:34:46 am »
I have Royal Enfield Electra 5s UCE. Recently, I have hearing very weird slipping (overriding) sound very loud from my left side of my engine. This happens usually when I have taken a few miles of ride and then stop at a place kill my engine and then when I use the self start the engine starts and makes a weird sound and engine stops working.
Re: Sliiping Sound
« Reply #1 on: January 03, 2013, 10:37:04 am »
Sounds like the sprag clutch is going away. Learn to kick start it!
Re: Sliiping Sound
« Reply #2 on: January 03, 2013, 11:45:29 am »
+1.  Get your battery voltage checked.  If it's getting low it can also cause slipping when starting, otherwise it's just the sprag gone bad and will need to be replaced.
Royalista
  • phaneropter
Re: Sliiping Sound
« Reply #3 on: January 03, 2013, 05:32:05 pm »
+1
As I experienced myself, and many others, the stock sprag clutch is still a weak link. The replacement will be better. But won't be immortal.
Do try to kickstart. It's easy, it's fun, it's vintage, it looks cool.
When stuck in the mud then you may cheat. ;) ;)
moriunt omnes pauci vivunt
GlennF
Re: Sliiping Sound
« Reply #4 on: January 03, 2013, 06:11:18 pm »
+1
I only use the electric start on my B5 if it stalls in traffic or cute girls are looking (girls looking gives Enfields performance anxiety).
At home I bump start rolling down the drive in neutral and kicking up to 2nd and dropping the clutch just before the road. I then stop and let it warm up a minute or two before riding off. I have a long drive and can get up to 10mph or so giving me an easy start.
Otherwise I just use the kickstart. My B5 starts first kick on the center stand or after 2 or 3 kicks when sitting astride the bike.
« Last Edit: January 03, 2013, 06:14:12 pm by GlennF »
Royalista
  • phaneropter
Re: Sliiping Sound
« Reply #5 on: January 03, 2013, 07:23:08 pm »
Everyone should have a drive! ;D
hortoncode3
Re: Sliiping Sound
« Reply #6 on: January 04, 2013, 04:43:28 pm »
I  love my kick starter...use it all the time. It didn't start worth a crap with it  when it was new but once the engine broke in it was one kick only..
Re: Sliiping Sound
« Reply #7 on: January 04, 2013, 07:36:37 pm »
Well, that's encouraging...  sort of.  Mind if I ask how many miles before "broke in and one kick only"?
AussieDave
Re: Sliiping Sound
« Reply #8 on: January 05, 2013, 01:43:50 am »
 Yeah , mine starts easily now with a kick. Maybe its coz I'm more in tune now, I dunno. Can I just take the starter motor off? Coz I'm still not sure about that shiny plastic cover.
AussieDave
Re: Sliiping Sound
« Reply #9 on: January 05, 2013, 01:52:54 am »
On second thoughts that's probably a dumb idea.
Re: Sliiping Sound
« Reply #10 on: January 05, 2013, 04:05:52 pm »
Mine's a one kick starter if it's above 60o, or the engine's warmed up. However, if it's cold, all bets are off.
Just got my sprag replaced on the G5. The original was definitely demolished! The rollers were ground flat and the cages were all broken up.
Re: Sliiping Sound
« Reply #11 on: January 05, 2013, 07:09:01 pm »
Did you get to keep the damaged  parts?  It would be interesting to see a picture of them. :)
As for one kick starting, mine doesn't want to kick start if it is cold.
I just got back from a hot rod/custom/collector car show and several of us watched a guy attempting to start his snorten Norton 740 Commando.
He give a mighty jump 5 times on his kick starter before it roared to life.
Although my bike had been sitting there for several hours I pushed the kick starter thru the compression stroke.  I turned on the ignition and let it boot up and raised the starter followed by one moderate push.  THUMP, THUMP, THUMP... :)
The other onlookers voiced their disappointment at my success.  What's a mother to do?  ;D
GlennF
Re: Sliiping Sound
« Reply #12 on: January 06, 2013, 03:45:09 pm »
Well kicking from just past TDC with the bike on the center stand standing beside it works for me even when cold. Sitting on the bike is a bit more hit and miss. The slight extra oomph you get kicking on the centre stand really seems to help.
These bikes do seem to flood easily though. First kick is best done with no throttle or enricher at all unless its really really cold. If it does not start after one or two kicks you will need to switch off the ignition and kick the engine over a few times to clear excess fuel before trying again.
Re: Sliiping Sound
« Reply #13 on: January 06, 2013, 07:59:58 pm »
Nope, I didn't get to keep them. Since it as a warranty deal they have to send the parts back to CMW. I didn't have my camera with me. I don't use those contraptions on my phone. I don't have any any to get a picture off!
blaisecardoz
Re: Sliiping Sound
« Reply #14 on: January 18, 2013, 11:06:52 pm »
its happens sometimes when on nuetral and sometimes when I stop on hills and try to roll up the hills.
