Jon's deluxe
33 Guests, 3 Users
Nixie, safeer1980, AVL Power!
February 10, 2016, 05:30:49 am
Author Topic: Cylinder Head Gasket Weeping Oil? Here's A .32 Cent Bandaid  (Read 4480 times)
Re: Cylinder Head Gasket Weeping Oil? Here's A .32 Cent Bandaid
« Reply #30 on: January 11, 2013, 11:38:17 am »
If you want to lap the head, typically the spigot will be much too high to do this by just lapping alone.
A good method would be to use a lathe to bring down the height of the spigot to be just a hair longer than the depth of the recess in the head.
You can check it by putting the head on the barrel and pushing it down all the way to be sure it's fully seated home, without any head gasket in place. Measure with an automotive feeler gauge, the empty gap where the head gasket would normally be, and that is your gap which needs to be narrowed. Reducing the height of the spigot carefully bring the gasket mating surfaces very close together so that very little lapping will be necessary, is the goal. Frequent checking of the gap by putting the head on the barrel will help you to gauge your progress, so that you don't shorten the spigot height too far.
The goal is to have the top of the spigot mate perfectly home into the head recess, at the same time that the mating surfaces on the head and barrel(where the head gasket used to be) come fully home together.
This will be accomplished in the final stage by lapping with valve grinding compound, as Royce Creasey describes.
I have found that lapping often allows some oil seepage to still occur. It's very hard to eliminate it without some sealer. So, a very light smear of hi-temp silicone sealer around the pushrod tube area should take care of any slight imperfections, and seal the oil.
I generally do not do the lapping process, but on occasion we have done it for some people who are at high elevations that need to increase their compression to the maximum extent possible because of thin air conditions at their locations in the high mountains.
neil
  • Neil & Buzzy the Bullet
« Reply #31 on: January 16, 2013, 01:25:45 pm »
Hello Fellow Bulleteers:
I had head/barrell oil leakage problems too. Ace suggested
using a mill file and carefully measuring the height of the spigot until you have a firm idea of how much of the spigot needs to be removed to get the proper seal between the recess in the head and the height of the spigot. I was able to do it and voila, the leaking has stopped. I used a copper gasket and gasgachinch on all mating surfaces around the top of the barrell and the surfaces of the gasket. It's not the type of material the gasket is made of, but the proper seal of the mating surfaces.
If I can do it --- everyone should be able to do it. Use a piece of glass to be sure the top of the spigot remains absolutely flat and parallel to the top of the barrell. The spigot seals the compression and a properly mating gasket seals the oil and - - - no more weeping of oil.
Try it, you'll like it.
Neil and Buzzy the Bullet
