29 Guests, 4 Users
Narada, cafeman, Ice, BeezrGeezr
May 25, 2016, 11:53:11 pm
Author Topic: Spark Plug for 2012 Desert Storm C5  (Read 1167 times)
atzelaner
« on: December 30, 2012, 09:44:37 am »
What other spark plug can be used for the UCE engine in a 2012 Bullet classic? I have a hard time finding the Bosch WR7 DDC4
Re: Spark Plug for 2012 Desert Storm C5
« Reply #1 on: December 30, 2012, 10:07:25 am »
You're lucky you couldn't find one. It's not the best one out there.
NGK BPR6ES has proven to be the most popular choice. About $3.00. Some people like the iridium version, but at around $10.00, I don't see the advantage. I changed my 6ES out at 15,000 miles because I had a new one. The old one still looked fine.
atzelaner
« Reply #2 on: December 30, 2012, 11:00:41 am »
Great thanks for the info. Will try the plug and install one.
atzelaner
« Reply #3 on: January 02, 2013, 09:09:40 am »
I received this reply from the NKG tech support "This bike will take part number BR8ES stock number 5422. I do show that all 500ís took this as OEM equipment".
I installed this plug and the engine starts and runs great.
« Reply #4 on: January 02, 2013, 11:50:57 am »
The 8 may prove to be a bit too cold. I haven't ever seen an Enfield come with an NGK unless it's something new. Actually that sounds more like the plug that was installed in the iron barrels. See my recommendation for the BPR8es in the post above, it's what the majority of the riders on UCEs on this forum are using.
« Last Edit: January 02, 2013, 12:05:51 pm by barenekd »
atzelaner
« Reply #5 on: January 02, 2013, 12:12:22 pm »
Great info, I willl try the BPR6ES. My engine has the EFI and the electronic ignition. Bare you are right the owners manual and repair manual only shows the Bosch plugs.
Mike
« Reply #6 on: January 02, 2013, 12:22:02 pm »
NGK BR8ES is an Iron Barrel 500 plug.
They all came with it.
