Fall riding
20 Guests, 2 Users
Mandar_C500, finbullet
June 01, 2016, 02:34:41 am
Author Topic: 2011 B5 Starter Solenoid Location?  (Read 2041 times)
GlennF
Re: 2011 B5 Starter Solenoid Location?
« Reply #15 on: January 01, 2013, 05:27:23 pm »
Have you successfully kick started it in the past before the electric start issue arose ?
B5er
« Reply #16 on: March 06, 2013, 09:39:25 am »
Thanks for all the input. The issue ended up being a frayed wire that the factory had tethered too tightly to the frame with one of those plastic zip-ties. But it was way up under the gas tank somewhere, making it a huge pain to find and repair. Thankfully all is well and the B5 is running once again.   :)
B5er
« Reply #17 on: June 19, 2013, 01:36:55 pm »
So, after what seemed like a successful fix, I'm having more electric issues with the B5:
Key turned, lights on, on/off switch "on," can hear the juice flowing, nothing from the starter. Kick-start doesn't work.
After I roll the bike up and down the block, I can start it in neutral with the clutch in after getting some "buzzing" from the starter. Bike runs great after, but continues to have the same problem after I stop, park and turn it off.
Also, blinkers work, but don't show up in the display.
