closeup
37 Guests, 2 Users
B5 Ben, Ducati Scotty
February 11, 2016, 01:16:45 am
Author Topic: Twist Grip/Throttle Options  (Read 1281 times)
cafeman
« on: December 29, 2012, 05:11:12 pm »
I'm wondering if anybody has any info regarding a twistgrip/barrel for the throttle that is faster, something like a 1/4 turn style, that will fit within the stock housing of an 01 Bullet? Or is a complete assembly swap out in order? :)
                     1996 Yamaha Seca II
                     1991 Husqvarna 350WXE
                     1991 KTM 250MX
                     2004 Husqvarna TC450
                     1995 Honda VFR750
nymonzajr
Re: Twist Grip/Throttle Options
« Reply #1 on: December 29, 2012, 07:11:48 pm »
I would think you will need an entire new housing.  A 1/4 turn throttle has a much larger diameter wheel where the cable hooks to than a regular throttle which is what makes it work faster.  Sorry I can't explained it better
« Reply #2 on: December 29, 2012, 07:41:46 pm »
If you have to swap out the internals of a throttle, why would replacing the whole thing be any harder?
cafeman
« Reply #3 on: December 29, 2012, 08:30:13 pm »
If the throttle assembly of an 01  Bullet was like that of a dirt bike, or my 07 Benelli, one could just swap it out very easily. But the throttle is part of the switch housing which makes things a little more complicated. Probably something I'll have to live with I think.
                     1996 Yamaha Seca II
                     1991 KTM 250MX
                     1995 Honda VFR750
cafeman
« Reply #4 on: December 29, 2012, 08:31:31 pm »
duplicate post, ooops  :-[
« Last Edit: December 29, 2012, 08:35:43 pm by cafeman »
                     1996 Yamaha Seca II
                     1991 KTM 250MX
                     1995 Honda VFR750
« Reply #5 on: December 30, 2012, 06:00:39 am »
Oh, I thought the only thing on the right side was the kill switch.
There's more?  If not, easy enough to put a separate kill on there while you've got it apart.
« Reply #6 on: December 30, 2012, 06:11:23 am »
I have a Tommaselli quarter-turn throttle on one of my builds.
Just make your own cable ends.
cafeman
« Reply #7 on: December 30, 2012, 06:14:16 am »
Kill switch, headlight/pilot/tailight switch and starter button. One would have to swap out an entire housing with the wiring harness and/or do some splicing. Might be a project down the road, but for now it's on the back burner :)
                     1996 Yamaha Seca II
                     1991 KTM 250MX
                     1995 Honda VFR750
cafeman
« Reply #8 on: December 30, 2012, 06:15:30 am »
Any pics of it installed?
                     1996 Yamaha Seca II
                     1991 KTM 250MX
                     1995 Honda VFR750
« Reply #9 on: December 30, 2012, 07:59:22 am »
« Last Edit: December 30, 2012, 08:23:33 am by ace.cafe »
« Reply #10 on: December 30, 2012, 08:30:23 am »
How does a 1/4 turn throttle ride on the street?  I was always figuring they were probably a little touchy.
cafeman
« Reply #11 on: December 30, 2012, 08:40:42 am »
Every modern streetbike, and even a 79 Bonneville I've owned had what I would call a normal ratio, either 1/4 or slightly more. I'm not used to the one on this bike, which requires some arm and wrist contortions to really open it up. But it is probably best for the slow speeds the bike operates at. Maybe it's just a matter of conditioning myself to stop wanting to pin the throttle all the time, like on sportbikes.... :P
                     1996 Yamaha Seca II
                     1991 KTM 250MX
                     1995 Honda VFR750
« Reply #12 on: December 30, 2012, 09:16:13 am »
Well, I hope it does stop you from wanting to pin the throttle all the time, or else you are going to wind up with a pile of oily internal engine parts scattered across the road somewhere behind you.
« Reply #13 on: December 30, 2012, 10:11:53 am »
I would like to have a quarter turn throttle as that is what I've been used to for the past 50 years. I don't like having to regrip the stock one. However redoing the switch assy is not on my to-do list.
cafeman
« Reply #14 on: December 30, 2012, 10:39:56 am »
There will be no pinning of the throttle on this thing, that's for sure!
I just have to remember why I bought it in the first place.....to slow down and take it easy on the country backroads! Too many years zipping around on sportbikes, how quickly I forget.  ::)
                     1996 Yamaha Seca II
                     1991 KTM 250MX
                     1995 Honda VFR750
