My bike loves bling
May 01, 2016, 06:46:50 am
Author Topic: Possible AVL Carb options.  (Read 3049 times)
Coles89
« on: December 27, 2012, 06:21:00 am »
Hi all
   Has anyone on here had any experiance in using non standard carburetors on 350 avl engines. The standard CV carb on my bike is ok but it tops out at about 70mph. It would be nice if there was a set up out there that gave the motor a little more gusto at the top end.
Cheers
2008 RE Thuderbird 350 AVL
AVL Power!
Re: Possible AVL Carb options.
« Reply #1 on: December 27, 2012, 07:34:21 am »
Hello Cole,
I think AVL 350s had a true speed of 115kph, going by that you are pretty close to it. However, we did get better results when we tried few VM carbs. We tried VM28,30, 32 and also Flat Slide 30's. They offer way more crispiness than the stock BS26 carb.
For now, I think you can play around with the existing carbs jetting. I also think that you can push the mainjet till 110 and pilot till 22.5 (not sure about the pilot). My friend has a similar setup but he's got free flow exhaust and airfilter, which is pretty compatible with bigger jets.
Oh !! and we also got rid of the PAV and catcon - that helped a bit.
-Sanket
Coles89
« Reply #2 on: December 28, 2012, 05:12:00 am »
Thanks Sanket, will start looking into those alternative carbs. Ill make a start by removing that emissions rubish first though.
Coles89
« Reply #3 on: December 31, 2012, 07:33:14 am »
On the subject of removing the emissions gear, what size bolt should i source to plug the gap left by the pav?
Cheers
Olly
mattjohnson207
« Reply #4 on: January 02, 2013, 02:02:34 am »
Got mine from Hitchcocks
AVL Power!
« Reply #5 on: January 02, 2013, 02:33:05 am »
Sorry for the late reply Cole. My bike is at my friend's place, I will get the blanking nut specs once I go there. Will update ASAP.
St1g9203
  • Ride hard.. thump harder
« Reply #6 on: May 03, 2013, 07:22:35 am »
I am wondering if i can a plug a BS29 or BS34 in it. they are available in india for around 50$ each. Genuine items, powering Bajaj Pulsar bikes.
AVL Power!
« Reply #7 on: May 03, 2013, 08:06:16 am »
Hello St1g9203,
The biggest CV carb that you can buy in Indian market will be BS33, used in Royal Enfield UCE500 (Carbed version) and the Pulsar 200NS by Bajaj. But if your bike's inlet port is around 28mm then why go for such big carb? It won't help anyways. I have seen 350s using 30mm flat slides, they work pretty well, the difference of 1mm or 2 is fine I feel but 6mm difference is just too much for the 350. I am pretty sure that the low end crisp will just die. If you want to experiment with carbs then the next best option for you will be a BS29 with ported throttle slides :)
-Sanket
St1g9203
« Reply #8 on: May 03, 2013, 10:59:57 am »
Hello St1g9203,
-Sanket
Thanks for your quick input Sanket. I have zeroed in on the BS29 Carb.
Can some one put the jet sizes of BS29 used in RE (TBTS models)
Adrian
« Reply #9 on: May 03, 2013, 02:52:49 pm »
Just a thought, but didn't the early AVL 350s use 26mm Dell'Orto carbs? A slight hike up to a 28mm Dell'Orto ought to give you some tuning potential. Likewise. a properly jetted VM28 Mikarb off a 500 cast iron Bullet could be a budget tuning option. Also the stock AVL cams might be limiting your top-end performance, this is certainly the case on the 500 AVL models.
REgards,
A.
AVL Power!
« Reply #10 on: May 03, 2013, 04:31:22 pm »
I think the BS29 carb has 12.5 pilot and 110 mainjet, either that or 15 pilot and 115 mainjet.
REgards,
A.
Only the first series of AVL 350 bikes came with Dellorto, PHBH 28 carb, later changed to 26mm one, after few months. That was the Machismo A350, later came Thunderbird and Machismo (Not the A350) which had UCAL Mikuni BS26, not that great as the Dellorto ones :D
DanB
« Reply #11 on: May 03, 2013, 05:36:04 pm »
I think the BS29 carb has 12.5pilot and 110 mainjet, either that or 15 pilot and 115 mainjet.
On the 500 AVLs its:
15 pilot
110 main
Needle on middle clip with spacer
2006 AVL Electra
anantkrishna
« Reply #12 on: June 09, 2013, 04:16:50 am »
I am using a DellOrto PHBH 28 BS - R3311 carb on my AVL350. Its the best upgrade possible from the old CV carbs.
Available here - http://www.dellorto.co.uk/merchandise/products_details.asp?PartNo=R3311&CategoryID=2&PartsectionID=20
