It's been quiet in the UCE section recently...
So I've been thinking about winter projects, and my planned fork oil replacement, which includes removing the forks, is foremost on my mind. It leads me to ask about my front fender.
Some of you may recall that when I bought my bike and started putting some miles on it, evidence began to appear that the fender was rubbing against the fork tubes - I lost a fair amount of paint from the tube, which is the part I can see, and possibly also the edges of the fender, which I can't see. I posted a pic a few months ago - it shows the right side, which is the worst, but I've got some paint missing from the left tube as well.
As I understand it, the bikes come crated from the factory with the front wheels and fenders un-mounted, so I'm led to believe that either, a) there is some manufacturing defect which causes these parts not to fit together correctly; b) the fork tubes were somehow not aligned properly at the factory when the front end was assembled; or c) the fender was not mounted properly when the dealer set it up. Any of the above would, in my opinion, fall into the realm of warranty repair, and in fact Kevin Mahoney agree to as much when he saw one of my postings this summer.
Despite this, what I'm looking for is some advice about dealing with this fender. I wouldn't normally think much about it, but I find myself in a situation where everything looks to me like it should, and yet, assuming there isn't some actual factory defect, I've had two separate RE dealers screw up this fender mounting. The original dealer produced the original problem, and my "first-service dealer" tried to realign the fender by loosening all the fender struts and retighten them, again and again, holding the nuts inside the fender with a wrench, and turning the screws outside the fender with a too-small screw driver, which chowdered the screw heads and scratched the paint around them. So now I have scratched up fork tubes and fenders.
And if
they can't do it right, I harbor concerns that I might not be able to, either.
I've read through Ducati Scotty's fork tutorial, and he mentions fender handling - specifically, in the reassembly stage, he says:
"Put the fender back on, it takes a little wiggling. VERY IMPORTANT: Make sure the divots in the sides of the fenders are centered with the fork covers. If they're not they could rub off some paint."
Now this seems like it goes without saying, but say it he does. My fender looks to me like its centered perfectly between the fork covers, both side-to-side and front-to-back. The problem occurs when the forks travel - the alignment between the fender and forks changes and they chafe.
With everything assembled, I stand where I can see the problem area but I can't compress the forks to see what's happening. I can stand on the bike, hold the front brake, and push down as hard as I can, but I don't weigh much and I don't get much movement, and anyway from that position I can't see anything. So even though I intend to have all the scratched up bits replaced this coming season, I'd like to get a sense of what I should be doing to make sure this doesn't happen again.
My questions:
In your-all's experience, if everything looks even and centered, should the tubes and fender stay clear of each other? Is it likely that when the forks travel, the alignment between them and the fender changes so that I might expect this chafe to occur despite them appearing ok at rest?
Would it be prudent to try to align the fender with the forks either partially or fully compressed? I could mechanically compress them, with tie-down straps perhaps, and then try to align everything. Part of the problem is when the forks are fully extended, the tubes hover above the fender "cutouts", so it's difficult to really tell if everything is truly centered.
Is it possible that the fork tube is not installed correctly? I seem to recall somebody suggesting that cardboard from a paper-towel roll could be inserted between the tube and fork leg to act as an alignment spacer.
Any advice would be appreciated! Well, any advice about fender alignment...
