Airbox bracket
33 Guests, 3 Users (1 Hidden)
Mandar_C500, gizzo
April 29, 2016, 05:07:17 am
Author Topic: Bullet Turm Signal Flashing Problem  (Read 1463 times)
b.sheets
« on: December 13, 2012, 05:01:39 pm »
Alright so after searching the forums for the answer I came up short so I am forced to ask the question....
I installed bullet turn signals on my 2012 C5 and all went well until I turn on the left turn signal and looked at the flashers....they blink in a random pattern, unlike what a normal turn signal flashes like. The right side is perfectly fine but the left side has a "double time" flash....the front and back light up but something is not right.
I feel like I just read about this but like I said, I used the search button.
Thanks in advance....not sure whats up.
2012 C5 Special(SOLD)
2013 Triumph Thruxton
Re: Bullet Turm Signal Flashing Problem
« Reply #1 on: December 13, 2012, 05:20:09 pm »
Are you sure you attached the + lead to the center bulb terminal and grounded the bullet turn signals case to a good ground?
This is just a guess because when I changed my OEM signals for the metal bullet style I made the mistake of believing the colored wire was the + wire.  It turned out that when they connected the short branch from the main harness to the OEM lights the colored wire became the - (ground) and the black became the + (power).
Unlike yours, when I attached the signals believing the colors, the lights refused to light at all.
I did figure out that the flasher is a solid state device rather than the old fashioned clicker type and the wiring polarity does make a big difference.
You might want to use a volt/ohm meter to check out which wire is the ground and which one is the + power supply.
b.sheets
Re: Bullet Turm Signal Flashing Problem SOLVED
« Reply #2 on: March 19, 2013, 01:19:32 am »
an updated flasher relay unit from superbrightleds.com fixed the "Random" flashing pattern my turn signals had after adding the bullet turn signals.
http://www.superbrightleds.com/moreinfo/led-vehicle-replacement-bulbs/cf12anl-01-led-bulb-electronic-flasher/781/835/
just thought I would add my findings as I am very happy now that I have a normal turn signal pattern again.
« Reply #3 on: March 19, 2013, 05:17:21 pm »
The other thing you can do is to replace the bulbs in the new turn signals with the ones from your OEM signals.
« Reply #4 on: March 19, 2013, 06:21:20 pm »
+1 ... the OEM bulbs are slightly higher wattage, and noticeably brighter in the bullet housings.  I will do this when I switch out my turn signals...
b.sheets
« Reply #5 on: March 19, 2013, 06:50:57 pm »
such an easy solution that didn't even occur to me.
thanks for the input!
