My new used 1999
February 09, 2016, 12:32:54 pm
Author Topic: Penetrating Oils  (Read 1214 times)
Afro Samurai
  • Afro Samurai
Penetrating Oils
« on: December 12, 2012, 08:02:11 am »
For those of us.. who actually need info like this from time to time..
Read below…
From what I could track down.. this is probably the origin of the information…
  http://bbs.homeshopmachinist.net/threads/47279-Penetrating-Oil
other searches…
http://www.google.com/search?q=machinist+workshop+article+%2B+penetrating+oils&sourceid=ie7&rls=com.microsoft:en-us:IE-Address&ie=&oe=
http://www.google.com/search?q=atf+acetone+mix+%2B+rusted+bolts&sourceid=ie7&rls=com.microsoft:en-us:IE-Address&ie=&oe=
Penetrating Oils
 Machinist's Workshop recently published some information on various penetrating oils.   The magazine reports they tested penetrates for break out torque on rusted nuts.   A subjective test was made of all the popular penetrates, with the control being the torque required to remove the nut from a "scientifically rusted" environment.
Average torque load to loosen:
No Oil used ................... 516 pounds
WD-40 ..................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF - Acetone mix............53 pounds
The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission fluid and acetone.  Note this "home brew" released bolts better than any commercial product in this one particular test.
Our local machinist group mixed up a batch and we all now use it with equally good results.
Note also that Liquid Wrench is almost as good as Kroil for 20% of the price.
ATF-Acetone mix is best, but you can also use ATF and lacquer thinner in a 50-50 mix. (ATF=Automatic Transmission Fluid)
LarsBloodbeard
Re: Penetrating Oils
« Reply #1 on: December 12, 2012, 03:29:12 pm »
Very nice!  I'm going to mix my own bolt-breaker juice now.
Does the type of ATF matter?
« Reply #2 on: December 12, 2012, 04:09:15 pm »
Any of the automatic transmission fluids will work.
Lwt Big Cheese
  • Getting there, slowly...
« Reply #3 on: January 04, 2013, 06:01:11 am »
I guess you didn't read the linked thread. A reply there says:
How stupid of you to repeat this BS. If you had tried it you would know that acetone and ATF do not mix anymore than oil and water. You should put some of each in a container and hope you live until they mix.
 :o
No warranty implied or given.
May contain nuts.
Afro Samurai
  • Afro Samurai
« Reply #4 on: January 05, 2013, 07:20:23 am »
Ok...i just found it...some say yes...others say no....at best all info is only 50% correct until you test it yourself...so dude...have fun with it or move on...
Lwt Big Cheese
« Reply #5 on: January 07, 2013, 08:08:37 am »
I heard vinegar is good, and also diesel. But never done a proper test.
May contain nuts.
mikail gransee
« Reply #6 on: January 16, 2013, 05:33:55 pm »
I  agree with diesel fuel...also a good cleaner/coating. I personally been experimenting with VELCRO.  :o
-"ONCE YOU STOP CONTRIBUTING, YOU BEGIN TO DIE",   -ELENOR ROOSEVELT
1999 Enfield Bullet
1977 Yamaha xs360 TD
1978 Yamaha xs 400 D
2005 Yamaha YZF 600R
2007 Honda CBR 1000RR
« Reply #7 on: January 16, 2013, 06:52:48 pm »
Diesel fuel is about the same thing as WD-40
« Reply #8 on: January 16, 2013, 07:31:32 pm »
For rusted on fasteners, I have only had success with a blow torch or hack saw.
Maybe I should try vinegar.
