500 as she was
February 06, 2016, 09:50:25 am
Author Topic: Duckbill  (Read 2209 times)
LarsBloodbeard
Duckbill
« on: November 29, 2012, 01:57:46 pm »
Anyone who has attached a duckbill breather to your iron barrel, could you please post pics?
Since the breather hose is too small to fit over the crankcase output, I have a small piece of larger diameter hose bridging the two, but I can't seem to get that air tight.
t120rbullet
Re: Duckbill
« Reply #1 on: November 29, 2012, 02:20:20 pm »
LarsBloodbeard
Re: Duckbill
« Reply #2 on: November 29, 2012, 03:19:35 pm »
Nice highway pegs.  How is your breather hose attached?  I can't quite tell in the pic.  Almost looks like it's stretched over the output, in which case you must have shaved some metal off or something, no?
t120rbullet
Re: Duckbill
« Reply #3 on: November 29, 2012, 07:23:31 pm »
That duckbill was made to fit over the nipple on the side of the crank. The metal bracket with the rubber grommet that holds the duckbill is stock also. That's the stock breather setup Enfield used for ever.
http://nfieldgear.com/enfield-store/aftermarket-parts-accessories/performance/duckbill-breather-hose.html
I don't know why it says it's for kick only bikes. I've put em on ES bikes at least up to 04 when they put most of the breathers on top of the oil tank.
CJ
LarsBloodbeard
Re: Duckbill
« Reply #4 on: November 29, 2012, 08:01:08 pm »
That's the one I bought.  There's no way it would fit over the nipple.  The OD of the duckbill hose is smaller than the OD of the nipple!
The description has a note that seems true to the ES, in my case: "Can be adapted to the electric start bikes with a small piece of slightly larger diameter hose."
Re: Duckbill
« Reply #5 on: November 30, 2012, 05:09:04 am »
Keep an eye on that breather system with the duckbill after you put it on.
The late model bikes with the breather off the oil tank don't breathe well, because the breather was never supposed to be moved to that location. It was some form of "pollution control update" that never worked well.  The breather should be on the side of the crankcase, as shown in t120bullet's photo. We always retrofit that breather on all performance bikes because that's the type that really works.
That being said, what you want to do in the meantime with your 2008 is to run a piece of hose that fits that nipple in the top of the oil tank, and run it straight up to the area under the seat, and THEN make your turn of the hose to wherever you want the outlet. That acts as a "stand-pipe" for the breather, so that any liquid oil being spewed out will probably not make it up that high, and run back down into the oil tank.
You can put the duckbill on the end of that hose, wherever you want to lead it. I lead it along the fender brace to the tail of the bike, and terminate it with a duckbill near the license plate. Others run it to the chain area as a "chain luber", but I'm not really a fan of that.
Anyway you can run it where you want. The "stand pipe" routing is important because the newer oil tank breathers tend to eject oil in fairly significant burps, and that's why there are all the complaints about oil-soaked air filters, etc.
Re: Duckbill
« Reply #6 on: November 30, 2012, 12:17:48 pm »
I ran my G5 breather hose up and back to the rear and ended it about at the rear seat mount. I thought about sticking the duckbill in it, but it's never blown any oil up there, so  I left it off. Works great. Just like the old Triumphs.
LarsBloodbeard
Re: Duckbill
« Reply #7 on: November 30, 2012, 12:30:21 pm »
Tom, mine is a 2003.  I'll upload a pic in a couple hours.
Bare, the catch can would collect quite a bit of oil on my bike, so it definitely needs an outlet for it.
Re: Duckbill
« Reply #8 on: November 30, 2012, 01:49:45 pm »
The UCE is a completely different arrangement with a wet sump and an integrated transmission with larger internal crankcase volume.
The Bullet has specific requirements with the small volume dry sump.
« Last Edit: November 30, 2012, 01:53:11 pm by ace.cafe »
Re: Duckbill
« Reply #9 on: November 30, 2012, 03:47:43 pm »
The UCE also has a chamber designed into the breather system which buffers the pressure surges giving the air/oil vapor a chance to separate inside the transmission area.
I think the UCE must be overfilled WAY over max before it will start blowing oil out.
In 8000 miles of riding, a lot of it at 50-70 mph there has never been more than a very light. almost non-existant film of oil that collected adjacent to the vent inside my air cleaner box.
LarsBloodbeard
Re: Duckbill
« Reply #10 on: November 30, 2012, 06:24:51 pm »
Here's mine.  It has a constant fake whisper sound (pss pss pss pss) since I can't get it air tight.  I can't clamp the hose to the hose because it'll just compress them both.  And the duckbill hose is not loose in the larger hose.  It takes some effort to get it in there.  So just curious to see what others have done with an ES iron barrel like mine.
Blltrdr
  • cycle-delic music
Re: Duckbill
« Reply #11 on: November 30, 2012, 07:47:09 pm »
I don't see what the problem is. Maybe the paint is slightly thick around the nipple. You can take some sand paper or a file and shape that nipple a bit so the breather hose slips over a little easier. You do want a slightly tight fit. If you do file or sand plug the breather hole with something to keep any shavings or dust out of the breather nipple. What year is your bike? Is it an '03/'04? Where is it from? That doesn't look like a VIN # on the engine.
2003 Classic 500 5 spd
2009 HD FLHTPI Police 103
jedaks
Re: Duckbill
« Reply #12 on: November 30, 2012, 08:29:57 pm »
I had the same problem and I solved it by going to the hardware store and buying a plastic tube that is used to join/mend a garden hose. Just clamp the tubes to either end of it and off you go! My crankcase breather is above the oil tank.
In 12,000klm of riding, it works just fine.
ROVERMAN
Re: Duckbill
« Reply #13 on: December 01, 2012, 06:35:16 pm »
My 03' has the stock breather tank and internal duckbill arrangement which has worked perfectly for the last 4-5 yrs. The previous owner replaced the original engine to vapour separator with some fuel rated hose,work's great.
Robert.
baird4444
Re: Duckbill
« Reply #14 on: December 02, 2012, 10:58:39 am »
I'm pretty sure I used 5/16 or 3/8 ID fuel line to slip over that when I re-did mine. Then a barb connector can be used to connect the duckbill where ever you please.
                  - Mike
'My dear you are ugly,
 - Winston Churchill
