I'm sorry, i meant the tool which is a gauge for tightening and alignment of the swing arm.it looks like a flat bar of steel with two holes drilled in it. its part #st25110-3 , i suppose its cheep enough bit if i knew the length id be tempted to make my own....... as far as bushings you can get a heavier set from the dealer that wont wear as fast,and that's what i was planning. sorry about the mix up.
