Here's a caveat, which I have seen elsewhere, the electronic ignition is very sensitive to battery condition.
I made the mistake of not pulling my battery until deep into winter.
I put it on the charger this spring and it takes a charge, but within a few hours the voltage has dropped from 13-14 to 10..
I got out for a test ride finally yesterday afternoon. The ride lasted for about an hour and by the end the battery was dead as a door nail, sdespite the fact that the charging system showed about 13.5 volts at the battery when running.
Due to the battery condition, by the end of the ride I was experiencing severe pre-ignition. I made it back home, but only barely.
So, if you are going to go electronic, make sure your charging system is fully up to snuff.
