Author Topic: MY SIDESTAND UPGRADE REPLACEMENT  (Read 1694 times)
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
on: November 20, 2012, 10:20:49 pm
I mentioned in another post that I did not like the angle of lean the stock sidestand gave my G5 Deluxe. I did not want to mend something on to the original stand. In looking around, I found that a stand from a 1976 Kawasaki H1, with spring & bolt, would do just what I wanted. I had to widen the original bolt hole, & use 2 washers as spacers. Enclosing some photos of my results, You can also see my "badboy"airhorn, Replacement shocks, & tire pump etc. I really like the new angle better, the new stand does not interfere, or get in the way of the other stand at all.
Best Regards, Craig McClure Jasper Ga. USA
Best Wishes, Craig McClure
GlennF
Reply #1 on: November 20, 2012, 10:34:52 pm
Looks like it was meant for the bike. Good find.
What do you mean by "tyre pump" ?
Craig McClure
Reply #2 on: November 20, 2012, 11:11:23 pm
Guess it is hard to see, but on my lower rear frame tube, there is indeed an accessory tire pump. got it from one of the DOMI RACER sales years ago, & it finally found a home on my G5 Deluxe. I picked up the 1976 Kawasaki kick stand for $8. on Ebay. Hope Enfield management copies it & sells them someday, it is perfect.
Regards, Craig McClure, Jasper Ga. USA
LarsBloodbeard
Reply #3 on: November 20, 2012, 11:29:22 pm
That's a stealth pump!  How difficult is that little thing to use on those tires?
Craig McClure
Reply #4 on: November 20, 2012, 11:38:19 pm
As in the old saying, "Ferocity of attack, compensates for size" obviously it requires more work than a big pump, but it is there with you- if you should need it.
Craig McClure, Jasper Ga,USA
motorat
Reply #5 on: November 20, 2012, 11:41:48 pm
i have one of these....
i paid $10 for it last year, used it a couple of times.
http://www.ebay.com/itm/BIKE-MICRO-MINI-TYRE-MOTORCYCLE-PRESSURE-FOOT-PUMP-STORAGE-POUCH-/400337321765?hash=item5d35f6bf25&item=400337321765&pt=UK_Motorcycle_Parts&vxp=mtr
it's small and fits in my tool pouch.
Joe
08 dl650abs
 c5 military
singhg5
Reply #6 on: November 22, 2012, 04:47:37 am
Looks nice and less lean angle ! Great find.
1970's Jawa /  Yezdi
2006 Honda Nighthawk
2009 Royal Enfield Black G5
gremlin
Reply #7 on: November 22, 2012, 12:36:50 pm
good job !
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
