the new RE Woodsman
February 08, 2016, 09:42:50 pm
Author Topic: Jack for use with bike/sidecar  (Read 962 times)
GA-DK
« on: November 20, 2012, 02:42:41 pm »
Dimensions are not critical.  They were based on what was in my shop at the time and the size of my tool pouch.  I started with 6.25" of tubing and 6.25" length of all-thread stock.  Stock is 1/2 - 13 thread and tubing is 5/8" OD and just over 1/2" ID.  I made a wing-nut from 1/4" brass, about 4" long.  A common nut for which you have a wrench in tool kit could be used.  I made a foot and saddle from aluminum scrap on hand.  The foot could be a short bolt with large head, such as an "elevator screw" used for leveling tools, refrigerators, etc.  The saddle could be a hex nut to fit threaded stock with a notch cut in top with bench grinder, hacksaw, or the like, and fixed to top of threaded stock with a drop of Locktite or epoxy.  You just need something to keep it in place without damaging paint.  I went the route I did because I have a lathe and mill in the backyard.  If you need to remove tire from sidecar or bike it is very handy.  I have even used it to make slight adjustments in sidecar alignment.  It can slightly spread sidecar frame from bike frame.  If the frames need to be pulled together slightly, loop a 3/8" rope around them, tie, and put tube through rope and twist.  This is much more controlable than a bump with the hip.  GA-DK
GA-DK
Re: Jack for use with bike/sidecar
« Reply #1 on: November 20, 2012, 02:47:58 pm »
Sorry, I forgot to attach photos.  GA-DK
« Reply #2 on: November 20, 2012, 03:31:34 pm »
Very ingenious. :)
