Author Topic: To K&N or not  (Read 3185 times)
saint45
on: November 20, 2012, 06:00:10 am
I have a G5 and am wondering if anyone has upgraded to the K&N. Worth it?
gremlin
Reply #1 on: November 20, 2012, 12:59:21 pm
nah, it's one of those things you do.   No real benefit & it costs as much as 5 of the stock air filters.
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
Lwt Big Cheese
  • Getting there, slowly...
Reply #2 on: November 20, 2012, 03:22:46 pm
If you want more crap entering your engine go ahead. Some prefer the style regardles of what may enter. Remember lots of people have no filtration at all, just bell mouths.
See the threads on oil where hours are wasted on arguing over very little. Where some insist on oil A over oil B because of increased engine longevity, then put a K&N on where the filtration isnt as good as stock.
Pays your money takes your choice.
No warranty implied or given.
May contain nuts.
hortoncode3
Reply #3 on: November 20, 2012, 03:52:18 pm
If I had to to do all over again i wouldn't have bothered. No noticeable increase in performance and you still have to buy cleaners and such for the "reusable filter"..it's not worth it. Plus it's fit is sucky.
Reply #4 on: November 20, 2012, 05:47:24 pm
I like mine, It fits good, filters well and makes some nice carb sucky noises.
Cleaning costs a lot less than a new filter, and I won't need to probably ever replace this one.
But you pays your money and makes your choices.
AVL Power!
Reply #5 on: November 20, 2012, 06:20:22 pm
I like the UNI Filters. Foam type and never faced issues with those filters even in rain. Did a 300km trip in rain and without any issues.
Also, I used K&N for sometime and didn't like it at all. My carb's slide was covered with dirt... even when it was oiled properly! UNI doesn't do that to me atleast.
-Sanket
Reply #6 on: November 20, 2012, 09:59:41 pm
I used to put Unis in Triumphs back in the day. I definitely found that they didn't flow as much air as the stock air filters. Some of the Triumphs would not run at top end with them. Totally cut out. I quit using them.
« Last Edit: November 21, 2012, 05:30:51 pm by barenekd »
saint45
Reply #7 on: November 20, 2012, 10:42:17 pm
Thanks a lot to all you guys! I'll leave well enough alone.
I had just heard you should do it with the EFI pipe, which I have.
AVL Power!
Reply #8 on: November 20, 2012, 10:51:52 pm
I used to put Unis in Triumphs back in the day. I definitely found that they didn't flow as much air as the stock air filters. Some of the Triumphs would run at top end with them. Totally cut out. I quit using them.
I heard about that a lot.. so what if I run the UNIs without the oil? will it let dust particles in? Never tried that :)
-Sanket
Reply #9 on: November 21, 2012, 05:31:59 pm
Yes, the dust will go right through.
Reply #10 on: November 21, 2012, 10:01:49 pm
The dust can go thru a un-oiled K&N air filter but the instructions say to oil it with their (high dollar) oil.
The first time I oiled the K&N I bought, my G5 had a very noticeable drop in power so I removed the filter and did a (home made) air flow test on it.
With the oil applied as it was, it was about twice as restrictive as the stock paper air filter.
Using K&N's degreasing fluid to remove the oil, I applied just a hint of oil to the filter and tried again.
My airflow test showed that the K&N was now, less restrictive than the stock paper filter so I thought I was on the right track.
I reinstalled the K&N in my G5 and buttoned it up.
My seat of the pants dynometer told me that most but not all of the horsepower had returned.  This was most noticeable at high rpm's where the engine seemed to run out of wind.
 During the next tank of fuel my fuel mileage dropped a bit.
Without some elaborate test equipment and a transparent air box that duplicates the stock one on my bike, I'm guessing but I decided that the larger, tapered body of the K&N filter was actually decreasing the open area into the throttle bodys intake.
In other words, the filter body, being larger placed it right up next to the air intake causing it to restrict airflow into the engine.
Following this experiance, I replaced my old paper filter.
The engines power seemed to return and the old fuel mileage did return so that's the filter I'm now using.
Others results may vary. :)
Reply #11 on: November 21, 2012, 10:47:54 pm
I'll cast my lot in with the paper filter people.
But you have to change them out regularly, or they'll plug up.
Reply #12 on: November 21, 2012, 10:56:50 pm
I have a parallel sided K&N in mine. A lot more area than the tapered one.
I can't say it adds any power, but I never felt like it lost any.
AussieDave
Reply #13 on: November 24, 2012, 12:46:02 pm
On account of the very small holes in the hydralic lifters i reckon it might be wise to stay on the clean side ....I've read mixed reports about the k&n... whats the consensus?
AwL
Reply #14 on: November 24, 2012, 04:37:49 pm
Since installing K&N filter on 2009 G5 have noticed an irritating high pitched whine when engine under load (55 mph with sidecar).  Going back to the stock filter...
