My 1988 bullet 350
May 27, 2016, 01:10:12 pm
Author Topic: Ace Air canister on my UCE  (Read 929 times)
b.sheets
« on: November 18, 2012, 12:20:40 pm »
After shooting ace.cafe an email about his canister and a little back and forth traffic we figured out that his canister would fit on my UCE with little to no adjustment from the iron barrel set up.
The only thing I had to do to make it sit up right was add an addition to the bracket that is supplied with the canister, I went to lowes and found a 1.5 inch bracket and a bolt and that did the trick. The hose was the same and everything...all I did was remove the oval tool box and use one of the mounts for that. oh yeah, the throttle cables were a tight fit but it all worked out great and I'm super happy to gain a decent sized tool box and get rid of that oval!
Ace is pretty much the sh*t.
2012 C5 Special(SOLD)
2013 Triumph Thruxton
Re: Ace Air canister on my UCE
« Reply #1 on: November 18, 2012, 12:29:18 pm »
Well, it did get on there, and it looks good on the black bike!
Glad you are happy!
That aluminum shield around the air filter element can be moved around to the front to shield the element from rain, if you are inclined to do any rain riding.
Otherwise, it can be removed entirely if you want.
b.sheets
« Reply #2 on: November 18, 2012, 12:30:50 pm »
thanks ace. I actually did move it after I took the pictures, without knowing what it was at the time common sense kicked in and saved the day.....Thanks!
GSS
« Reply #3 on: November 18, 2012, 12:39:06 pm »
Very nice!
2014 GT - Red
2010 C5 - Teal
It's a Jeep thing......
« Reply #4 on: November 18, 2012, 02:19:27 pm »
Pretty much?  No sir - he is most definitely the sh*t!
