Cape Cod Vintage Sidecar Tours
33 Guests, 5 Users
oTTo, Ice, ace.cafe, mattsz, cafeman
February 07, 2016, 07:30:55 am
Author Topic: A new LED question  (Read 1372 times)
b.sheets
A new LED question
« on: November 14, 2012, 06:16:29 pm »
I bought the suggested LED bulbs for the pilot lights and speedometer. The replacement of the pilot lights went well...took 3 minutes total. Next I took the headlight out and pulled the neutral bulb out of the speedometer, pulled the bulb out and......damn, its a wedge base bulb.
Not the BA9s bulb http://www.superbrightleds.com/moreinfo/ba9s-ba7s/ba9s-led-bulb-4-led/6/
.... has anyone with a 2012 C5 replaced their speedometer bulbs with LEDs? What bulb did you use? I found this one http://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-4-led-wedge-base/198/ any ideas?
again... I have a 2012 and after doing my research, watching the youtube video on how to do the swap and also attempting it myself it is safe to say that the 2012 speedometer uses the wedge based bulbs....
« Last Edit: November 14, 2012, 06:55:33 pm by b.sheets »
2012 C5 Special(SOLD)
2013 Triumph Thruxton
GSS
Re: A new LED question
« Reply #1 on: November 14, 2012, 06:45:38 pm »
Sounds like another continuous improvement stealth upgrade.
2014 GT - Red
2010 C5 - Teal
It's a Jeep thing......
b.sheets
« Reply #2 on: November 15, 2012, 10:21:50 pm »
well, I ordered  http://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-4-led-wedge-base/198/
Let's see if they'll work. I guess I don't mind figuring this out for the 2012 owners.
b.sheets
« Reply #3 on: November 19, 2012, 09:04:30 pm »
For what it's worth to any 2012 Bullet owner the below link is the correct LED bulbs for your speedometer. There are a wedge base bulb not the BA9s bulb that previous years use.
trial and error, youre welcome.
sethne
« Reply #4 on: May 17, 2013, 02:59:42 pm »
the 2012s use wedge base bulbs in just the speedometer or the neutral and turn signal as well?
b.sheets
« Reply #5 on: May 18, 2013, 08:26:34 am »
it uses wedge based bulbs in all three indicators that are housed in the speedo. your brights indicator, neutral indicator and turn signal indicator.
sethne
« Reply #6 on: May 18, 2013, 09:26:38 am »
the speedometer backlight as well correct?
b.sheets
« Reply #7 on: May 21, 2013, 09:22:43 am »
i didnt replace that bulb. but it mightbe safe to assume, yes.
JVS
  • I love chicken
« Reply #8 on: May 21, 2013, 09:27:10 am »
sethne,
Before you buy the LEDs, it is still better to make sure what type of bulbs you have, even if your C5 is a 2012. You never know yours might still be the older type bulbs (non wedge type/pins)
It doesn't take long to take out the bulbs from the housing in the nacelle. Just be careful. The speedo backlight comes out the housing easily, if pulled correctly  :D
Bulletman
  • 2011 - C5 Classic Black
« Reply #9 on: May 21, 2013, 10:59:41 am »
sethne,
Before you buy the LEDs, it is still better to make sure what type of bulbs you have, even if your C5 is a 2012. You never know. Just be careful. The speedo backlight comes out the housing easily, if pulled correctly  :D
+1
"A Blast from my Past"
Mark F   (Northern, CA)
Black C5 2011
wildbill
« Reply #10 on: May 24, 2013, 07:28:23 pm »
2012 has the wedge version. found that out a few days ago.
for a quick trial i bough a couple from super-cheap and they work fine and pretty bright at that.
2011 C5 black/chrome
2012 C5 maroon/chrome
2013 B5 black
2014 Continental gt
2014 C5 tan
2015 black/chrome
2015 limited edition dispatch
2016 lagoon blue
2004 mazda-speed miata
2001 bmw z3
