Military theme- powdercoat
July 29, 2015, 08:53:02 pm
Author Topic: Good source for manual for C5 with UCE?  (Read 615 times)
mplayle
« on: November 13, 2012, 09:03:18 pm »
I have a deposit placed on a C5 Military UCE (with sidecar) and will be picking it up this coming weekend.  I'm located quite a way from the dealer, so will be doing much of my own routine maintenance.  (There was a dealer local, but they apparently dropped RE from their inventory.)  Where is a good source for obtaining a service manual on the current models with the UCE?
singhg5
Re: Good source for manual for C5 with UCE?
« Reply #1 on: November 13, 2012, 09:15:49 pm »
Welcome to the Forum.
Service Manual and related material can be bought from hosts of this website -
http://nfieldgear.com/enfield-store/merchandise/books/uce-technical-library.html
1970's Jawa /  Yezdi
2006 Honda Nighthawk
2009 Royal Enfield Black G5
« Reply #2 on: November 13, 2012, 09:20:02 pm »
If there is a local dealer you can order it there.  Otherwise just call our host and they'll have the factory manual.  It does assume certain level of mechanical aptitude.  If you're a beginner you probably also want a general moto manual to fill in the gaps.
Pete Snidal puts out an excellent manual for the older bikes but his UCE manual is very basic.  I have it but I wouldn't buy it again.  Probably the kind of thing that would help a total beginner with basic maintenance.
mplayle
« Reply #3 on: November 13, 2012, 09:29:27 pm »
Thanks for the quick replies.  I went checking the "books" section of the host site and thought the set posted by singhg5 might be the right set to get, but wasn't sure.
I'm not a beginner to basic maintenance - my other "hobby" is classic Minis (have a 1961 in the garage).  Just new to RE's and been away from motorcycles for 10 years.
« Reply #4 on: November 13, 2012, 09:48:07 pm »
If you know how to keep a Mini running, the Royal Enfield will be a piece of cake for you.
perri
  • Italy
c5 2009 italy
