New G5 Military in New York
18 Guests, 4 Users
Good Vibes, REpozer, cafeman, Ice
May 06, 2016, 12:35:25 am
Author Topic: Bike wouldn't start in the cold this morning...  (Read 4231 times)
jonico61
  • La Balita Roja: 2011 Electra 500cc EFI
  • Riding the Bull in Spain
Re: Bike wouldn't start in the cold this morning...
« Reply #30 on: November 21, 2012, 08:53:14 am »
New battery, definitely. My stock battery only lasted a year, died in the 30º winter here. I bought a new battery with a few more amps to it, re-rigged the battery frame holder since it was ever so slightly bigger (damn!) but haven't a had a problem ever since.
2011 Bullet Electra 500cc EFI
www.abulleteerinspain.blogspot.com
LarsBloodbeard
« Reply #31 on: November 21, 2012, 01:15:32 pm »
Out of curiosity, what did you do to the battery holder?  I've been thinking of putting a stack of washers on the bolts behind mine because the battery the dealer gave me hits the frame and the cover won't go on.   ???
« Reply #32 on: November 22, 2012, 12:13:30 pm »
To avoid the lurch fan the clutch a few times with the engine running and the bike in neutral before you put it in gear.
FWIW, I can fan the clutch lever 'till the cows come home, but it doesn't free up the stuck clutch plates.  The best method for me is the pre-start hold clutch in / kick lever method (I have a kick start lever).  It doesn't come easy.  In warmer days, I could use the push bike with clutch in method, but now that it's cold, it's too hard.  The engine turns, or the back wheel drags...
Gremlin heads for the hills…
« Reply #33 on: November 22, 2012, 12:32:35 pm »
If it's gotten that drastic, start it on the center stand, pull the clutch and put it in gear, then drop it on the ground...That'll do it! :o
« Reply #34 on: November 22, 2012, 12:51:54 pm »
Is that different than having the bike idling and putting it in gear?  When I do that, it stalls.
« Reply #35 on: November 23, 2012, 05:58:45 pm »
That sounds pretty harsh.  Is your clutch adjusted properly?  Does the bike have any shifting issues?  If yes and no, then I guess yours is just stickier than most.
