Royal Enfileld AVL
12 Guests, 1 User
Tarnand
May 29, 2016, 02:46:43 am
Author Topic: Headlight replacement  (Read 1225 times)
Gypsyjon
« on: November 12, 2012, 09:33:51 pm »
Can replace the stock headlight with a 5 3/4 inch head light with an H4 bulb?
TIA
Re: Headlight replacement
« Reply #1 on: November 12, 2012, 10:49:21 pm »
I could be wrong but I seem to recall someone saying there isn't enough room behind the light bulb because of the speedometer location?
I could be wrong though. :)
« Reply #2 on: November 12, 2012, 11:13:19 pm »
Yes, I did exactly that.  It can be tight but it will fit.
If you get an auto light instead if a Moto light the locator tabs won't line up, but you can just tighten it in there and it shod be fine.  You can also go cheap and just get a 5 3/4" sealed beam halogen at any auto shop.
« Last Edit: November 13, 2012, 12:06:22 am by Ducati Scotty »
drbvac
  • Low as it can go
« Reply #3 on: November 18, 2012, 08:19:52 am »
You can also go with the larger chrome retainer ring and us a larger auto Halogen - looks better and brighter.
Dr B
TWinOKC
« Reply #4 on: November 18, 2012, 08:52:44 am »
Does anyone know the part number of a sealed beam halogen headlight that will fit our bikes?
I am too lazy to experiment.
2010  C5  Teal
2011 Triumph Bonneville T100
2015 Scrambler Ducati
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
« Reply #5 on: November 20, 2012, 04:33:37 pm »
Hi, I'm selling my like new, bulb & rings on Ebay, probably as cheap as you can buy just the bulb. That way you will have spares to replace broken or rusted bits. Item # 110977404258.  Check it out!
 Thanks, Craig McClure, Jasper Ga, USA
Best Wishes, Craig McClure
TWinOKC
« Reply #6 on: November 21, 2012, 12:47:22 pm »
Thanks for your offer.
I was really just looking for the part number of a sealed beam automobile halogen headlight that would fit our bikes.  Doing a search, I came up with H4467?
I know the 7" works better and looks great but is a little more expensive, just trying to get a better headlight for around $10.   ;) ;)
2010  C5  Teal
TWinOKC
« Reply #7 on: November 21, 2012, 04:59:36 pm »
I see where Nfield Gear now has their 7" halogen headlight on sale.
Fits everything but the C5    Just my luck.   :(
http://nfieldgear.com/enfield-store/featured/sale/pre-assembled-7-headlight-kit.html
2010  C5  Teal
motorat
« Reply #8 on: November 21, 2012, 05:46:28 pm »
of course they do!!!!
i just bought one saturday.
well at least i supported my favorite dealership.
btw
i love the light!!
Joe
08 dl650abs
 c5 military
« Reply #9 on: November 21, 2012, 09:59:06 pm »
The code symbols in my Nfieldgear catalog says the # 145017/a headlight kit that the Sale takes you to will fit all 9 of the RE models including the C5.
The only thing I see about it that could be a negative is the light is rated at 55/60 watts.
If the bike is ridden at normal speeds without a lot of stops that should be OK but if it is used to just putt along and sit at a lot of stop lights that could run the battery down.
« Reply #10 on: November 22, 2012, 12:51:02 pm »
I have a 55/60 watt Sylvania sealed beam in my bike. It has never been a problem. If you were to have a problem, it's probably the stock battery.
My charging system puts out about 13.6 volts at idle with or without the light on. It goes up over 14V as the revs go up. It is plenty adequate for the system.
If the headlight assy will fit a G5, it will fit a C5, it's the same casquette.
drbvac
  • Low as it can go
« Reply #11 on: November 22, 2012, 04:39:29 pm »
I just bought the 7" replacement ring and took it to my local auto supply store and tired halogen bulbs in until found one that fit - took it home - put the clips around the sides and clipped on the electricals and screwed it on = took 1/2 hr.
Sylvania H6024ST SilverStar 65-Watt High
Dr B
