1914 Royal Enfield
May 30, 2016, 05:22:21 pm
Author Topic: Yuasa YTX14AHL-BS  (Read 1166 times)
edthetermite
  • The Emperor has no skin.
Yuasa YTX14AHL-BS
« on: November 10, 2012, 09:47:32 pm »
After four years she died. Won't take a charge. I like that it is an American product so I will be inclined to replace it with the same thing. Odyssey batteries are also highly rated and I have one in my Ural but they are very pricey. Decisions, decisions. Not having an e-start any longer may mean I can get by with less. If I knew for sure the Odyssey would do ten years, as claimed by some, I don't think I could resist getting one.
Update: Odyssey batteries are all too long to fit our trays.  :-[
« Last Edit: November 12, 2012, 10:17:24 pm by edthetermite »
Ed   - Long Live the Iron Barrel !!!!
2008 Military RE "535"    2006 Ural Gear Up
cafeman
Re: Yuasa YTX14AHL-BS
« Reply #1 on: November 11, 2012, 05:56:04 am »
Has anyone looked at Shorai or Ballistic lithium type batteries? Much smaller and in most cases more cranking power as well as light weight compare to lead-acid type, and they can be mounted in any position . Might be something to consider when relocating the battery to the toolbox or other area.
http://www.webbikeworld.com/motorcycle-battery/li-ion-motorcycle-battery/shorai-vs-ballistic-li-ion-motorcycle-battery.htm
« Last Edit: November 11, 2012, 05:59:06 am by cafeman »
                     1996 Yamaha Seca II
                     1991 Husqvarna 350WXE
                     1991 KTM 250MX
                     2004 Husqvarna TC450
                     1995 Honda VFR750
« Reply #2 on: November 11, 2012, 07:09:25 am »
The Kick Start models have a 5 amp-hour battery in them.  You don't need 14 amp-hour with a kickstart only bike.
edthetermite
« Reply #3 on: November 11, 2012, 08:21:41 pm »
This is true. But I can tell you for a fact that a non-charging 14 amp hour Yuasa will take you close to 200 miles w/o a charge to it. I got within 4 miles of the house before mine went below the 'sufficient spark' threshold. The wife was not thrilled to help me load the bike in the pickup.  ;D
GreenMachine
« Reply #4 on: November 12, 2012, 09:26:45 am »
I just installed another Yuasa 14ahl as the Bike Master Gel battery crapped out just after a year..In addition, I  picked up a schumaker load tester on sale for 20 bucks....Too many machines with batteries not to have one....GM
Oh Magoo you done it again
edthetermite
« Reply #5 on: November 12, 2012, 10:18:39 pm »
Load Testers are great and not an arm and a leg to buy....
