Eggs
28 Guests, 2 Users (1 Hidden)
Nixie
February 11, 2016, 03:05:19 am
Author Topic: Striped stud  (Read 523 times)
Dhastings1954
  • 98 bullet Machismo
Striped stud
« on: November 10, 2012, 08:02:51 am »
Hi
When I replaced my rocker assemblies, one of the studs that holds the rocker blocks is nearly striped. It is not very tight at all. Should I fix it? If so would you recommend tapping in an oversize stud or trying a helicoil?
One of the studs that holds the rocker covers on completely strip when I put it back on. Same question I guess
Thanks for your ideas
Duncan
Vt Bullet
Re: Striped stud
« Reply #1 on: November 10, 2012, 08:07:35 am »
Usually a helicoil or insert will work.
5 ft-lbs torque on all rocker stud nuts. NO more than that.
20 ft-lbs torque on head stud nuts.
Re: Striped stud
« Reply #2 on: November 10, 2012, 04:53:03 pm »
For those curious about how much force 5 ft/lbs of torque on those little nuts will create, the answer is over 1250 pounds (567 kg) each.
That's over 5,000 pounds (2,268 kg) for the four fasteners.
Re: Striped stud
« Reply #3 on: November 10, 2012, 05:50:06 pm »
Helicoil them.  ERC
