The Duchess
40 Guests, 2 Users
cstorckiii, tracendaz
April 30, 2016, 03:41:21 pm
Author Topic: Tire Bead Breaker Levers  (Read 602 times)
« on: November 10, 2012, 12:14:39 am »
RE tires are not the easiest ones to come off the wheels.  A pair of Bead Breaking Levers from Motion Pro seem to be worth having for changing tires or for replacing tubes.  One lever has forked end and the other a sharply unpturned end.  Instead of side-by-side use, one lever is place below and the other on top of that to break the bead.
http://www.cycleworld.com/2012/11/09/motion-pro-bead-pro-tire-bead-breaker-levers-tool-time/
« Last Edit: November 10, 2012, 12:21:10 am by singhg5 »
Re: Tire Bead Breaker Levers
« Reply #1 on: November 10, 2012, 07:21:43 am »
That looks like a good tool. I've got a big breaker that will do cars too. looks as if you could use those and take up a lot less space.   ERC
