100 MPH!!!
May 25, 2016, 08:09:38 am
Author Topic: Returning To Motorcycling And Thinking of Royal Enfield  (Read 2637 times)
Shavuotis
« on: November 07, 2012, 07:38:23 pm »
Hello Everyone:  I am about to return to motorcycling after a 15 year absence from it.  I really want a Royal Enfield C5 in Desert Tan or OD Green.  I am not what you would call a mechanic.  But I want a bike I can service and work on myself.  I don't want to have to pay someone $$$$ per hour to do work and service I can do at home.  My question is this:  Are RE's easy to work on at home or do you need a mechanics degree.  I have owned several motorcycles in the past, one suzuki, two Kawasaki's, and a Honda.  I never did anything more than adjust the tappets on my Honda and change front end bearings on my Kawasaki.  Is an RE too much for a returning newbie?  Any info would be greatly appreciated.  Thanks  :)
squire
Re: Returning To Motorcycling And Thinking of Royal Enfield
« Reply #1 on: November 07, 2012, 07:54:10 pm »
In my opinion it is an easy bike to work on. I can't recall how many bikes I've owned but this is one of the easiest to work on, the only exception may be some of the UJMs from the seventies.
GlennF
« Reply #2 on: November 07, 2012, 09:18:28 pm »
Regular service on a UCE bike like the C5 should normally consist of:
- adjust and lube the chain (10 minutes max)
- change engine oil and oil filter (30 minutes)
- check and tighten where necessary all important nuts and bolts including the spokes . (10 minutes)
wildbill
« Reply #3 on: November 07, 2012, 09:25:21 pm »
i think you will do it easy. my last bike was in 73 and i do all my own work on this one.
also great lot of blokes here - always willing to help with good advise.
buy the bike - you can't go wrong.
2011 C5 black/chrome
2012 C5 maroon/chrome
2013 B5 black
2014 Continental gt
2014 C5 tan
2015 black/chrome
2015 limited edition dispatch
2016 lagoon blue
2004 mazda-speed miata
2001 bmw z3
« Reply #4 on: November 08, 2012, 08:02:27 am »
The tasks are simple, however, the skill required to do them is higher than anticipated.
example = stripped threads.
the RE uses a relatively soft aluminum casting for the engine, therefore, they use fine pitch threads to reduce the amount of torque required to properly clamp surfaces.
what does this mean to a tool noobie ?
It means :: stripped threads.
when you are tightening any of the fine thread screws on the bike you *MUST* use care not to overtighten.
palace15
« Reply #5 on: November 08, 2012, 08:30:00 am »
Get a UCE that has a kickstart !!
Shavuotis
« Reply #6 on: November 09, 2012, 07:42:41 pm »
Thanks for all the input guys.  I really appreciate it.  Three more questions:  Have any new problems surfaced with the new UCE  EFI motors?   What tools would I need to do all the service and repair work on the bike?  I want to be able to learn with this bike and do any required work aside of specialty work like repairs that would require machining.   :)
« Reply #7 on: November 09, 2012, 09:13:19 pm »
As was mentioned, there is very little to do on the new UCE powered bikes.
You will probably want to get a complete set of metric wrenches and sockets because the RE nuts and bolts are made to the European standard.
Hex sizes like 13mm aren't common on the Japanese bikes but I've found several on my RE.
Although they are adequate for the job, some of the Indian steel fasteners aren't the greatest thing around and in many places the steel fastener/plug screws directly into cast aluminum.
Because of this I highly recommend buying a good torque wrench if you don't already have one.
The only machining I've had to do is to modify some of the aftermarket parts I've installed.
Apparently the idea of precision tolerancing and fit hasn't made it into the designs of some of these and I have yet to install something that didn't need a hole enlarged or elongated with a rat tail file to fit. :)
« Reply #8 on: November 10, 2012, 12:00:42 am »
Hi Shavuotis and welcome aboard.
There was a recall in 2009 for a transmission problem but that was addressed and none have given trouble.
Like the brothers said a decent set of euro-metric tools, nothing extravagant.  You probably have the rest of the stuff I.E. drain pans, tire pressure gauge etc.
« Reply #9 on: November 10, 2012, 12:08:40 am »
And we promise not to tell your wife when you buy new tools you "need" that you really don't need ;)
Aside from the usual wrenches, etc., this forum will be the most important tool you have.
« Reply #10 on: November 10, 2012, 04:31:52 am »
If you're expanding your stock of metric tools, you might want to consider adding the rear axle socket sizes needed to adjust the chain, which you'll be doing occasionally with the OEM one.  I don't recall the socket sizes - I don't have the sockets!  I've been using a big adjustable wrench and it's a PITA.  They're posted around here somewhere, or maybe somebody knows off the top of their head and can chime in...
« Reply #11 on: November 10, 2012, 12:58:27 pm »
Harbor Freight has a 3/4" socket set that goes from 19mm to 50mm for about $25. that will give you a socket to fit any of the large nuts on the Enfield, from Brake backing plate nuts to countershaft sprocket nuts. It includes a looong ratchet, a breaker bar and extensions. It's well worth the money.
Just don't get a hernia toting it around!
« Reply #12 on: November 10, 2012, 02:08:32 pm »
Does 50mm cover the large nut for the front sprocket?
« Reply #13 on: November 10, 2012, 02:50:44 pm »
Yes, I think it's a 45 or 46MM. I forget now, but it's why I bought the set!
It would cost that much just to get the one socket from Sears or some other tool shop.
« Reply #14 on: November 10, 2012, 02:56:23 pm »
Just what I was thinking!
