Author Topic: Problems with power  (Read 1647 times)
JesterNT
  • Maintenance is as much art as it is science.
on: October 25, 2012, 02:29:04 am
My C5 left me stranded tonight. The bike has good power from the battery, the headlight and horn work fine.  The bike just keeps dying, it stars up and runs fine low to high rpm and drives fine for a mile or two but then cuts out like I turned it off. If I quickly rock the kill switch on/off I can keep it running for a few minutes more but in the end it stops.  After letting it sit for a few minuets it fires back up again and drives another 1/2 mile or so. Are there any electrical component that could overheat and cause this behavior? In the past I had a issue with the kick stand switch that produced similar situation, but I disconnected the switch and it's making no difference.
Quando Omni Flunkus Moritati
GlennF
Reply #1 on: October 25, 2012, 02:42:42 am
Faulty kill Switch ?
Reply #2 on: October 25, 2012, 02:51:35 am
Inside the nacelle on the left jus by the fork leg is a connector that can come apart.  Just two wires. Tend to come apart when the bike vibrates or you turn to one side.  Check it.
Desi Bike
Reply #3 on: October 25, 2012, 02:58:17 am
Fouled plug? Mine would display the same attitude until I warmed / rev'd the snot out of it and cleared the plug for a short while until out fouled dead again. Drop a new plug in and see what happens.
میں نہیں چاہتا کہ ایک اچار
bluesdaddy2
  • aka Ross
Reply #4 on: October 25, 2012, 11:37:52 am
Side (kick) stand switch, maybe?
Oops, looks like you already tried that. (I missed that in your post).
« Last Edit: October 25, 2012, 05:51:09 pm by bluesdaddy2 »
2012 Royal Enfield C5 Chrome/Black
1938 Harley-Davidson Model U (patiently waiting some TLC)
1975 HD Sportster (Gone but not forgotten)
Vergennes, VT
Ilion, NY
Reply #5 on: October 25, 2012, 03:08:20 pm
+1.  That switch sucks!
Reply #6 on: October 25, 2012, 04:56:05 pm
But he's already disconnected it...
Reply #7 on: October 25, 2012, 07:34:20 pm
The component that usually causes that is the crankshaft position sensor. As you say, it heats up then quits. After it cool down a bit it'll go again, until it heats up again. It's in the right case by the alternator. It controls the ignition timing.
Triumphs are notorious for this failure. I've had a few with them.
