Here's what may be an interesting twist to the story - or I might just be hijacking my own thread! My bike has always "clunked" heavily into first gear when cold, or should I say, when unridden for awhile. I can warm it up at idle, but that first shift is a hard clunk and a jerk, even if I "fan" the clutch two or three times before shifting. After that first clunk, I can shift right into neutral and right back again into first without further incident. Once that initial shift is done, it is fine until I shut it down and let it cool off.
This morning I warmed the bike up for about 1-1/2 minutes while I got my helmet and jacket on. It was cold out, 33 deg. F, but the bike spent the night in the garage which was about 50 deg. I hopped on, fanned the clutch in and out two or three times as I usually do before shifting a cold bike into 1st, then held the clutch in with 2 fingers to where the lever just about touches my 2 remaining fingers on the grip, like I usually do. But this time when I shifted down into 1st, the bike jumped and stalled, as if I wasn't holding the clutch in at all! I'm glad I was holding the brake with my right hand! I returned it to neutral, started it back up, and it shifted lightly into 1st, just like it always does the second time.
My clutch cable seems to be adjusted fine - I have no other issues or problems than the initial cold "clunk". But this was serious - I think without the front brake engaged, it might have knocked me down. Could my idle adjustments have something to do with this?
