WHEN YOU DO CHANGE YOUR BATTERY, USE ONLY AN AGM TYPE BATTERY. It will not cause corrosion anywhere, or puke acid on your chrome or paint. & it lasts longer & is stronger.
Also I prefer my terminals to the out side of the battery, so no frame contact can occur. You can always put a rubber/bubble wrap cover over it to prevent frame cover panel contact.
I have had good success with Motobatt, Deka, & Odyssey brand batteries. Mottobatt being cheapest, Odyssey being highest. I'm Running a medium priced Deka in my 2010 G5 Deluxe,& like it fine.
