My 07 Red Dlx, left
February 08, 2016, 09:51:49 pm
Author Topic: 2009 Royal Enfield won't start, sat in storage for almost a year  (Read 1685 times)
randombikerdude
  • USA Rider
I was out of the country and stored my bike inside my condo, I drained all the fluids and removed the battery. Now I can't get it to turn over, I've replaced with fresh gas and even tried seafoam in the carb. Any ideas???
LarsBloodbeard
Re: 2009 Royal Enfield won't start, sat in storage for almost a year
« Reply #1 on: October 19, 2012, 02:41:50 pm »
Did you fog the engine when you stored it?  Is the engine frozen or does it cycle at least?
TWinOKC
« Reply #2 on: October 19, 2012, 10:48:21 pm »
Try the easy stuff first.
Is the kill switch in the run position, key on, side stand up, petcock open, in neutral?
2010  C5  Teal
2011 Triumph Bonneville T100
2015 Scrambler Ducati
« Reply #3 on: October 19, 2012, 11:19:32 pm »
what do you mean, you can't get it to turn over? You can't kick it through? It just won't fire? Please clarify.
randombikerdude
  • USA Rider
« Reply #4 on: October 21, 2012, 06:41:29 pm »
I've tried the ES and KS, sounds like it wants to get going just doesn't turn over. The engine is not stuck, I can hear it. I didn't fog it, what does that mean?
boggy
  • Karma Ultra: 7
« Reply #5 on: October 21, 2012, 06:48:58 pm »
Bet my peanut butter and jelly sandwich it's the spark plug.
2007 AVL
2006 DRZ400SM
randombikerdude
  • USA Rider
« Reply #6 on: October 21, 2012, 07:32:31 pm »
Spark Plug, that is what I was thinking.. since I've tried everything else..
LarsBloodbeard
« Reply #7 on: October 22, 2012, 12:01:47 am »
A lot of people don't do this, it's more popular with boat motors.  You can save yourself some potential frustration if you do do it though.
Fogging oil comes in a spray.  You just spray it in the intake while opening the throttle a bit.  Keep spraying till it kills the engine.  That prevents internal corrosion and rust (such as, on the spark plug).
Personally, I think this is more important to do now than ever.  E10 is more corrosive than pure gas, and it collects water which will speed up rusting drastically.
« Last Edit: October 22, 2012, 12:03:57 am by LarsBloodbeard »
