Actually there is a difference in coils. The primary resistance. It's 3 ohms on a Bullet. too low resistance, will draw too much current, resulting in fast point wear, too high, and the spark will be weak.
Coils use a ratio of primary to secondary windings,that determine the output voltage.
A higher voltage to the plug will smooth out the idle, but at the expense of point wear. The Bosch blue, is in the catalog, It's been around since the sixty's, and has been the standard in step up items.
