i have been messing with this gearbox for longer than i care to admit. here are the statistics and symptoms. 2002 military 4 speed with right shift conversion. first gear, no problem. will shift through all the gears if i am very careful with my footwork. if i shift as if i were riding a normal bike, it will shift right past 2nd (or 3rd,4th) and into neutral. it is the same when i down shift. by the time i get into 4th gear the neutral finder is pointing at 4th but as i down shift, it (the neutral finder) does not follow. it stays at 4th. i'm stumped and have no one in my area that will work on the bike (i've looked extensively). any and all suggestions will be appreciated.
