britts 09 bullet
May 04, 2016, 09:53:39 pm
Author Topic: Photo Size Limit?  (Read 838 times)
The_Rigger
Photo Size Limit?
« on: October 13, 2012, 11:39:58 pm »
I'm going to make a small request...
This evening, as I read the new posts, I was confronted by an attached JPEG photo, described as follows: "3092.94 kB, 4320x3240."
Really??  Was it really so important to show off your [*insert name of minor mechanical malady here*] that you had to attach a three megabyte photograph, measuring over four thousand pixels by over three thousand, to your post? That, in laptop screen terms, is a friggin' billboard.
Folks, please...  Have some consideration for people who A.) read the forums on small screens, and B.) suffer along with whatever sketchy internet access as we can find in hotels and jobsites around the world.  If you can't resize your photos down to 800x600 and a reduced bit depth, for the sake of the bandwidth-challenged, maybe you should be reconsidering posting photos at all.
Kevin: Is it possible to set up a maximum size limit on attachments, or would that be technically unworkable?
Thanks,
-Dave
2012 C5 Special
LarsBloodbeard
Re: Photo Size Limit?
« Reply #1 on: November 02, 2012, 03:02:04 pm »
I may be guilty of this.  I am going to resize from now on.  When I first uploaded some I assumed it would resize them appropriately.  Many forums do.
« Reply #2 on: November 02, 2012, 05:19:19 pm »
I think there is already a limit on the size the forum will take.   ERC
« Reply #3 on: November 02, 2012, 05:30:35 pm »
Maybe everyone already knows this but in addition to reducing the photos size, reducing the "dpi" won't hurt the image if it's just going to be seen on a computer screen.
The "dpi" can be as low as 75 before things start degrading and by reducing both the image size and the dip value multi-meg pictures can be brought down to less than 100 Kb.
When I do this I rename the  picture so it doesn't re-write it over my big file and its easy to find when I want to show it in a post/topic.
