Geichal's Bullet at Work
13 Guests, 2 Users
AVL Power!, The Old Coot
February 12, 2016, 04:16:25 am
Author Topic: Oil leak  (Read 861 times)
Dannyboy
Oil leak
« on: October 13, 2012, 06:09:12 am »
Just noticed this oil leak on my C5. Looks like a seal on the electric start. Bike is still under warranty so will get my dealer to check it out.
BRADEY
Re: Oil leak
« Reply #1 on: October 13, 2012, 12:38:12 pm »
Oil leak on a UCE is rare.............very rare. Yours is a minor one, and needs a silicon seal under the starter sprocket cover ! You can do it yourself, but if the dealer is nearby get it done under warranty. Why mess your hands just yet ;)
Re: Oil leak
« Reply #2 on: October 13, 2012, 05:04:52 pm »
I'm sure the dealer will be able to fix it but if it were mine I would at least use an allen wrench to see if the bolts had loosened.
Of course, this risks breaking off one of the bolts if it gets overtightened. :(
hortoncode3
Re: Oil leak
« Reply #3 on: October 16, 2012, 05:41:49 am »
Oil leak rare? My Aunt Fanny! Mine has all sorts of drips, nothing major, cosmetic mostly...with the exception of the constant self oiling chain!
Dannyboy
Re: Oil leak
« Reply #4 on: October 16, 2012, 06:06:55 am »
I did check the bolts but all were tight so will take it to the dealer to be fixed. Thanks guys,
Dan.
hocko
Re: Oil leak
« Reply #5 on: October 16, 2012, 05:31:08 pm »
Dannyboy Hi, I had the same leak on my '09 G5. There is no gasket there, I loosened all the screws, lifted the cover off, wiped it all over and replaced the cover with no sealant . 15000 km later still no leak. I must admit I did a 1690 km ride in two days a while back and there was slight misting on the metal but no leak as such. Hope this helps.
Cheers  :)
