La Balita in Spain: Seville
35 Guests, 4 Users (1 Hidden)
themikefish, cstorckiii, GTB535
May 06, 2016, 10:04:08 am
Author Topic: switched to the 7" headlight ammeter in the red since then  (Read 2688 times)
AgentX
Re: switched to the 7" headlight ammeter in the red since then
« Reply #15 on: October 18, 2012, 06:00:31 am »
Check battery, then if that's OK, alternator output?
« Reply #16 on: October 18, 2012, 04:48:13 pm »
You might want to remove the carburetor float bowl and check for water or debris.
On my old carburetored bikes I found it doesn't take much to make an engine finicky.
ammburger
  • do it with feeling
« Reply #17 on: October 18, 2012, 05:11:16 pm »
I'll take those suggestions to the bike. I did check the battery and it mostly hovered a bit above 12V. I have a analog tester so can't drill down too precisely. Once while idling the meter went down to 8V and started dropping. I went to check something came back tested again, back at 12V. It idled for another couple minutes then just stopped as if I turned off the kill switch.
Also, now it kicks back when the choke is open, I dialed back the air mixture and it seemed to help.... a little.
Finicky isn't the word!!  ::)
« Reply #18 on: October 19, 2012, 01:22:55 pm »
If your battery is dropping to 8V with a load on it, it is shot. You need a newie.
mikail gransee
« Reply #19 on: October 20, 2012, 12:25:49 pm »
On troubleshooting a problem, the best is to start with what you did right before the problem. The light swap. Loose wire shorting ?  Take the time check your wires and connections for bare copper or looseness.
-"ONCE YOU STOP CONTRIBUTING, YOU BEGIN TO DIE",   -ELENOR ROOSEVELT
1999 Enfield Bullet
1977 Yamaha xs360 TD
1978 Yamaha xs 400 D
2005 Yamaha YZF 600R
2007 Honda CBR 1000RR
pooletx
  • Texas Sixty-5 Driver
« Reply #20 on: October 20, 2012, 02:44:53 pm »
Speaking of switching from the smaller to the larger headlight, i cant seem to solve the mystery of the two wire high and low beam connection to the headlight and then the mysterious single Amber wire.  I have a 2004 Sixty-5 and i have no clue what to do with the amber wire.   I also have a new 50/40 bulb.  Any info is appreciated.
John
pooletx
« Reply #21 on: October 20, 2012, 04:52:00 pm »
... And now the old stock 5 1/2" headlight doesnt work!  Tried w multimeter to check Current and blue and green ( high and low beams ) and amber wire have juice.   Stumped.  Battery charged up.  Other lights working.  Horn working. Dang.
neil
  • Neil & Buzzy the Bullet
« Reply #22 on: January 27, 2013, 08:42:16 am »
John:
I to have a 2004 bullet 65 and my headlight is powered by the A/C circuit. No power and no illumination unless the engine is running to produce A/C power. That circuit is regulated by a separate voltage regulator. Don't know if this is helpful but it might help clear the question.
Neil and Buzzy the Bullet
« Reply #23 on: January 27, 2013, 02:16:31 pm »
Sounds like something in the carb.   ERC
