FAYETTEVILLE GA.
May 02, 2016, 10:02:06 pm
Author Topic: Replacing fork tube covers  (Read 825 times)
El Rojo
« on: October 10, 2012, 11:18:31 pm »
I need to replace my fork tube covers (the long ones) and I have a question-do I need to disassemble the fork sliders or can I simply remove the entire fork assembly from the clamp and casquette? If I have to remove the sliders are there special tools I need?
El Rojo
Re: Replacing fork tube covers
« Reply #1 on: October 11, 2012, 09:50:20 pm »
Help!  Anybody?
darmst6829
« Reply #2 on: October 11, 2012, 10:17:41 pm »
Thatís a big job. No special tools needed just a bunch of time. The lower triple tree needs to come out to change the covers. You may be able to leave the nacelle in place but I doubt it. I had to heat the nacelle with a heat gut to get the steering stem out. I would be looking at a service manual first.
El Rojo
« Reply #3 on: October 12, 2012, 01:11:12 am »
Ugh, that's what I was afraid of.  I have both the service manual and the Snidal manual I'll have another look at those.  The repair shop quoted me $720 for labor and I've got better uses for that kind of money.
« Reply #4 on: October 12, 2012, 07:12:21 am »
The only special tool you'll need is a big hex wrench to unscrew the forks. You can use the bar that holds your footpegs on if if you can't find a wrench that big. It's a pain in the ass job but all it takes is time.  ERC
« Reply #5 on: October 12, 2012, 09:51:15 am »
I use a hex head bolt. I put the bolt head in the top of the fork and double nut the threaded end with a washer in between the two nuts so it won't drop down into the fork. Have used this homemade tool a few times to take the forks apart.
2009 HD FLHT Police 103 6 spd
« Reply #6 on: October 12, 2012, 11:43:52 pm »
This is Genius!!  and so simple...
   I'm going to put this idea way up there with
Gedeon's bolt and cable method for replacing
the center stand springs.
Well Done and thank you for sharing.
