Right shift kit mod
34 Guests, 2 Users (1 Hidden)
JohnDL
February 10, 2016, 03:01:26 am
Author Topic: Silencer heat shield hardware strangeness  (Read 1166 times)
« on: October 08, 2012, 02:38:43 pm »
I started my bike today and heard a faint clattering sound - quickly chased it to the shield on the silencer.  One of the three hex-head screws securing it was gone.  I went to the hardware store with allen wrench in hand (pocket, actually), and removed a second screw to find a match.  It came out with little difficulty, with threads slightly surface-rusty but otherwise intact.  The shortest replacement I could find was just a hair longer than the original.
I put both back on the bike (they both went on fairly easily), and sure enough, the longer screw bottomed out just before the head clamped down on the shield.  I thought I'd grab a washer to fill the gap, but...  darned if I could get either screw back out again.  After I got home, I waited for things to cool down a bit, then went after both screws with penetrating oil, all the while thinking I was going to strip the hex socket or break the tool (not likely to break the head off the 6mm screw).  I eventually got them both out, with threads intact,  but what the heck is going on here?  I was going to lock-tite them, but now everything is saturated with penetrating oil.  Anyway, I don't see how they would have come out on their own as tight as they were.
Ideas?
Will residual penetrating oil bother blue lock-tite?  Will blue lock-tite work at all with the heat of the exhaust?
Re: Silencer heat shield hardware strangeness
« Reply #1 on: October 08, 2012, 02:46:24 pm »
Heat promotes oxidation.  Thing that get hot rust faster, simple as that.
I threw those silly little allen head screws away the first time I got them out.  I replaced them with standard hex head bolts in stainless steel.  I had to cut them down a bit but that was easy enough with a Dremel.  Now when I need to take them out past the accumulated rust I know I can get enough torque to do it.
The residual oil will block Loc-Tite.  Just use some solvent and a Qtip to clean them out.  At those temps no LocTite is going to hold BUT it will fill the gap with it's plasticky-ness and help prevent more rust.
« Reply #2 on: October 08, 2012, 02:59:07 pm »
The Loctite will work, but a better plan is to get a different muffler. I had the same problem with my stock muffler the day I picked it up. I heard the rattling but kinda dismissed it, and a few weeks later, got an EFI muffler and when removing the bazooka, found the heat shield screws loose.
« Reply #3 on: October 08, 2012, 03:07:10 pm »
My Boys!!!   ;D
Thanks guys!  I think I would like to replace the bazooka with an EFI, but I don't want the bike to be any louder.  Anyway, that will probably be next season's "project".
Solvent: Alcohol?  Acetone?  Mineral Spirits?  (That's all the solvents I have...)
Bulletman
  • 2011 - C5 Classic Black
« Reply #4 on: October 08, 2012, 03:17:36 pm »
My Boys!!!   ;D
Mattsz, I would enjoy a drink while doing it... Alcohol works really well..  ;D
"A Blast from my Past"
Mark F   (Northern, CA)
Black C5 2011
« Reply #5 on: October 08, 2012, 04:06:16 pm »
Acetone would work fine.  You just need something that will cut the oil.
« Last Edit: October 08, 2012, 04:29:16 pm by Ducati Scotty »
« Reply #6 on: October 08, 2012, 05:25:36 pm »
I doubt that Loc-Tite will last in that area of the muffler.
Based on the colors of the chrome plating I would guess it could get well over 700 degrees F.
A heavy split lock washer would probably do a better job of securing the screws.
« Reply #7 on: October 08, 2012, 05:27:28 pm »
Yeah, but it can't hurt either.
« Reply #8 on: October 08, 2012, 05:42:56 pm »
+1
« Reply #9 on: October 12, 2012, 06:18:26 pm »
... and, the washer might just be thick enough so I don't have to shorten the screws...
