In the fields
February 11, 2016, 09:57:21 pm
Author Topic: switch location  (Read 790 times)
aaremjay
switch location
« on: September 22, 2012, 02:01:39 am »
 8) 2002 Electra break neutral switch location
The Garbone
  • Shade Tree
  • User Complaints: 22
Re: switch location
« Reply #1 on: September 22, 2012, 08:57:41 am »
1995 Classic recess turn signal switch location.   :-*
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
Ragmas
Re: switch location
« Reply #2 on: September 23, 2012, 09:18:36 am »
Well since we are listing switch locations, Overhead light and ceiling fan switch location;  my wall just to the right of the door frame.
2009 G-5 Military
Little Falls, NY
Re: switch location
« Reply #3 on: September 23, 2012, 06:53:36 pm »
I suspect we are having a communication problem?
I'm also at a disadvantage because I don't own an old Electra so I'll have to make some guesses.
If we are talking about a Brake switch that operates the rear brake light there should be two of them.  One at the front brake lever and one connected to the foot operated lever.
If we are talking about a Neutral switch (assuming there is a electric starter) it will probably be mounted on the gearbox or gearbox cover(s).
It's job would be to prevent the electric starter motor from running if the transmission was not in neutral.
Seeing that there is no electrical devices in the transmission other than possibly this switch it would be the only thing that has a electrical wire connector.
Now, if we are talking about some other "break neutral" switch it might be on the handlebar clutch lever.
On most bikes with electric starters there is a switch there so the electric starter will operate after the clutch lever is pulled in, even though the transmission is in gear.
