BLACK
May 30, 2016, 03:28:15 pm
Author Topic: Clutch cables  (Read 757 times)
mustangdave
  • ACES UP
Clutch cables
« on: September 16, 2012, 09:11:36 pm »
This is kind of a follow on to a previous thread about clutch woes...and the semi continuing issue with WHITEY....previously...the clutch cable failed at the gear box....got (2) replacement OEM cables and the actuator arm mod....well it turns out that the bloody cable is to dang LONG, and after adjusting the cable tension there was still some slop in the shifting, the adjusting barrels at both ends of the cable were all the way out...and Justin and I just were not happy with the hard down shifting and missing NEUTRAL... so Justin and I collectively though....while we're in here tinkering lets take a look at the clutch and friction plates....they were NASTY...ordered some new plates and discs from CMW...and am finally ready to install these in hopes that is will cure what ills the bike....BUT I'm thinking "the cable will still be to long"...any thoughts or ideas....one that came from the previous thread was to find/use a longer barrel adjuster....I'm game for suggestions
I rode Japanese bikes as a kid...then I grew up and got some British Thunder
Re: Clutch cables
« Reply #1 on: September 16, 2012, 11:31:27 pm »
If the cable is to long then send it back. If you bought it from CMW they will send you a shipping label for the return. I have been sent wrong parts in the past and they have rectified all orders that had been shipped wrong. I would also suggest using the upgraded cables because they are worth the extra $$$.
2009 HD FLHT Police 103 6 spd
mustangdave
  • ACES UP
Re: Clutch cables
« Reply #2 on: September 17, 2012, 05:59:48 am »
UPGRADED cables? how so...
Re: Clutch cables
« Reply #3 on: September 17, 2012, 10:58:44 am »
Call CMW and ask for the premium cable/s.
mustangdave
  • ACES UP
Re: Clutch cables
« Reply #4 on: September 24, 2012, 08:00:58 am »
well got everything back together...still no joy...this problem WILL NOT DEFEAT ME....
Re: Clutch cables
« Reply #5 on: September 24, 2012, 09:01:33 am »
Have you tried adjusting the clutch release rod inside the trans cover?
mustangdave
  • ACES UP
Re: Clutch cables
« Reply #6 on: September 25, 2012, 06:32:45 am »
Yep, we did ACE....Justin and are going to go at it again...
