Ariel Red Hunter#1
February 08, 2016, 01:19:05 pm
Author Topic: False neutrals  (Read 1992 times)
squire
False neutrals
« on: September 05, 2012, 07:53:27 pm »
Anyone else have a LOT of false neutrals with these bikes? My C5 with nearly 300 miles really likes neutral, so much so that I can sometimes kick the shifter up 4 or 5 times and it refuses to go into gear. Sometimes when I am in gear it just drops down into neutral. When I can't get it into a higher gear I have to gear down and sometimes it takes a couple stabs and I go down two gears. Please tell me this goes away with increased mileage!!! I'm doing my first service today and I'm hoping that helps. I'm an experienced rider and my shifts are deliberate (purposeful?), I get the occasional false neutral when I get lazy on other bikes occasionaly but nothing like this. And it's getting worse with increasing mileage and emits no unusual sounds. Any ideas? TIA
TWinOKC
Re: False neutrals
« Reply #1 on: September 05, 2012, 07:57:27 pm »
As the miles add up the bike gets better, shifts better, more power, less vibration.
You might want to check the play in your clutch cable.
« Last Edit: September 05, 2012, 08:03:01 pm by TWinOKC »
2010  C5  Teal
2011 Triumph Bonneville T100
2015 Scrambler Ducati
hillntx
  • Shriner Bulleteer
  • 2011 C5 Classic
Re: False neutrals
« Reply #2 on: September 05, 2012, 08:05:40 pm »
I experienced periodic false neutrals when I got my C5, but over time they became less frquent and then went away.  Check your clutch cable and keep your shifts slow and deliberate.
Re: False neutrals
« Reply #3 on: September 05, 2012, 08:11:48 pm »
No advice here, but to say that I have a B5 (2011 - same engine, yah?) with 270 miles - no false neutrals, or any other shifting trouble at all, except for a good solid clunk into first gear (kinda like my old BMW, which did have false neutrals, by the way).  I think mine's idling high.
Clutch cable is the first thing I would check - thanks to the previous actually helpful replies!  Good luck!
jartist
Re: False neutrals
« Reply #4 on: September 05, 2012, 08:21:38 pm »
There's been quite a few threads about shifting and most everyone has been able to get it sorted.  Some have had good luck with clutch cable adjustment, some have changed shifting technique, and others just had the problem go away on it's own only to reappear when they changed shoes.
I had better luck letting the clutch out with the lever still in the shift position.  In other words pull clutch, pull up on shift lever and keep it up, release clutch then allow shift lever to return.  On downshift I make sure that I close the throttle before pulling the clutch.  Pre-loading shifts don't work with my bike at all for down shifting but work great for shifting up.  I pull pressure on the shift lever and then instead of pulling the clutch all the way I just pull the clutch until the gear clicks in.
There also was a thread about excessive in and out play on the shift lever where it comes out of the case causing vague feeling shifts, that's something else to check for.
Do a search for missed shifts or false neutrals and there's alot of other suggestions.  I'm sure you'll find what works best for you in the next 2-300 miles.  After 1000 miles you'll probably never miss a shift again.  I was ready to pull my hair out at first but I haven't missed a shift in the last 5000 miles.
shamelin
Re: False neutrals
« Reply #5 on: September 05, 2012, 10:16:39 pm »
I'll occasionally get false neutrals on my B5.  It usually happens when I'm doing some sloppy shifting- releasing the clutch too soon or not applying enough pressure to the shifter.  I haven't found it to get any better as miles accumulate, but it certainly gets better when I'm more deliberate in my gears.
GSS
Re: False neutrals
« Reply #6 on: September 05, 2012, 10:20:49 pm »
Set the play at the clutch lever to 2mm, shift slowly but deliberately, and by the time your have a couple of oil changes under your belt, the false neutrals will disappear.  These are not unusual during the breaking in period.
2014 GT - Red
2010 C5 - Teal
It's a Jeep thing......
squire
Re: False neutrals
« Reply #7 on: September 05, 2012, 11:01:49 pm »
Thanks everyone. The clutch was tight, I've adjusted it and I'll give it a go tomorrow.
Re: False neutrals
« Reply #8 on: September 06, 2012, 02:07:49 pm »
Many have found that the Royal Enfield transmission in the UCE seems to like slow deliberate movement of the shift lever for its full stroke.
The quick short snap shifts used on the Japanese bike transmissions usually end up putting the RE into a false neutral between the gears.
Re: False neutrals
« Reply #9 on: September 06, 2012, 05:54:29 pm »
It's just learning how to shift it the way it likes to be shifted. Take an aspirin and call us in a thousand miles!  ;)
GlennF
Re: False neutrals
« Reply #10 on: September 06, 2012, 07:45:02 pm »
Japanese sports bikes have short notchy shifters a bit like the gear lever in a Ferrari.
Enfield shifters are more akin to the gear shift fitted to a Kenworth prime movers.
Rich Mintz
  • Daily rider in the city
Re: False neutrals
« Reply #11 on: February 07, 2013, 11:54:34 pm »
For whatever it's worth: I have a 2010 Bullet with about 800 miles on it. I don't have any trouble finding neutral when up shifting fom 1st, but I'm having all the other issues reported, including:
- bike falls out of 5th or 4th into a false neutral and has to be kicked into gear again
- when downshifting, bike gets stuck in 3rd, I have to rev once to be able to kick it into 2nd, and again to get it into 1st
- when downshifting, I end up in a false neutral
These are all intermittent and don't interfere with my riding. I never have the sense that it'll fall out of gear and I won't be able to get it back in.
At the 600 mile service my dealer said this wasn't normal and offered to take the trans apart as a warranty service and see what's wrong. But based on what I read this may be typical. I'm going to keep riding to 1200 mi or so and see if it evens out. Deliberate shifting definitely helps.
Rich Mintz - New York City
richmintz@richmintz.com
[/URL]
Bulletman
  • 2011 - C5 Classic Black
Re: False neutrals
« Reply #12 on: February 08, 2013, 11:54:20 am »
Ive had my fair-share of false Neutrals when my C5's mileage was around 600 miles or so, Now I'm at 2600 Miles and the false neutrals are a thing of the past, Its just a matter of running in the bike and putting on the miles, like a fine wine, she just gets better with age. ( and use )  :)
"A Blast from my Past"
Mark F   (Northern, CA)
Black C5 2011
Re: False neutrals
« Reply #13 on: February 08, 2013, 12:30:07 pm »
Make sure the clutch cable freeplay is 2mm.  Make sure the shift lever is adjusted so that it's comfortable for you.  Good synthetic oil like Mobil 1 4T can help but mostly you just need more miles on the bike.  The bike gets better as it breaks in and you get used to its rythyms.
Royalista
  • phaneropter
Re: False neutrals
« Reply #14 on: February 08, 2013, 02:22:49 pm »
Footwear also has a large impact on successful shifting. I started having false neutrals when wearing heavy boots. Required some adjusting from my part, now false neutrals only occur when being sloppy. Otherwise shifting is smooth, including fast shifts.
With ordinary footwear the length of the shifter is just fine.
moriunt omnes pauci vivunt
