Near Upper Tujunga Canyon, on the way to Angeles Crest Highway
May 02, 2016, 04:19:53 pm
Author Topic: Tail light  (Read 954 times)
Nickolouse
Tail light
« on: September 04, 2012, 01:43:37 pm »
So I was riding home last night and someone yelled to me to turn on my tail light. It is suppose to always be on so I'm not quite sure what has happened. I haven't opened it up yet. The break-light works so I'm assuming its not a ground. I'm going to go out and start looking around for the cause in a moment any place you guys would look first?
1973 MG Midget
2009 Royal Enfield
Damon
Re: Tail light
« Reply #1 on: September 04, 2012, 01:53:43 pm »
they are usually a dual filament bulb, like an automotive 1157, so the brake light and tail light operate separate filaments so very likely the tail lamp side burned out.
 I just had the opposite on my Iron barrel, where the brake light wasn't working and I traced all through the bike for an electrical issue only to go where I should have started and found the bulb simply burned out.
Damon
2005 Bullet 612 Continental
1965 Interceptor Mk 1 restoration project.
The Garbone
  • Shade Tree
  • User Complaints: 22
Re: Tail light
« Reply #2 on: September 04, 2012, 01:55:05 pm »
Yup,  look for a new bulb..  I have LEDS in my bikes as the last good long time....
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
Nickolouse
Re: Tail light
« Reply #3 on: September 04, 2012, 02:04:37 pm »
I knew there was a good reason to ask you guys! Saved me some time looking for electrical issues. Thanks!
1973 MG Midget
2009 Royal Enfield
walken4life
Re: Tail light
« Reply #4 on: September 08, 2012, 09:10:22 am »
I had a good Samaritan point the same thing out to me a few months ago.  Brake/tail lights in general no one notices they are burned out unless someone else tells you.  It is a dual filament bulb as others have said.  Readily available at any auto parts store.
