The 5 3/4 light on mine ( as delivered ) was adjusted all the way down & to the right, however, it was actually pointing slightly high & to the left.
After installing the 7 inch glass the adjustment seems to be just fine now!
Well yeah, I'm going to wait 'til I get the seven-incher installed and see where it's point-of-aim is before doing any tweaking, of course... Whenever that may be.
My 5-3/4" light points just fine L-to-R, but it definitely wants to drop; on dipped-beam, the hot spot from the reflector is waaaay out, about 50 yards in front of the bike, high enough that the main beam is pretty much useless except for spotting 'possums in the trees by the side of the road.
I wonder if having the larger 19" front wheel has anything to do with it? Prolly not...
ObNothing: If this works, and I don't like the pattern the 7" lamp from Nfield throws, Cibea makes a 7" reflector assembly (takes an H4 lamp) that has a simply lovely projector pattern, lights up the sides of the road nicely for nocturnal Bambi-spotting (Bambi is a sore spot with me, obviously) in addition to a ginormous amount of light on the pavement... I had one of those on my first GoldWing with the Vetter fairing, from Daniel Stern Lighting... I may have to see if it's still in production.
