Out and about =D
May 30, 2016, 09:09:23 pm
Author Topic: Pegs/controls  (Read 1873 times)
ridgerunner
Pegs/controls
« on: August 24, 2012, 07:06:39 pm »
Has anyone seen a set of floorboards and heel-toe shifter that might work on the Bullet? I'd like to raise my feet a little to stop dragging my peg in left turns. As it is, my left peg folds nearly straight back.
08 Bullet ES (AVL)
The Enfield saves on gas, riding the Enfield saves on Prozac. ;)
AgentX
Re: Pegs/controls
« Reply #1 on: August 26, 2012, 03:39:09 am »
Indian Enfields often have a heel-toe shifter, direct from the factory I believe; check Ebay or one of the Indian sites like royalenfieldzone or bulletwalas.
As for floorboards I have no idea, but don't understand how they'd afford more clearance than pegs.
edit:  Here are some floorboards; annoyingly, the website requires you to ask for a quote by email rather than just give you the price online--
http://royalenfieldzone.com/handle_grips_and_footrest.asp
Not quite sure how they attach, though.
« Last Edit: August 26, 2012, 03:46:31 am by AgentX »
ridgerunner
Re: Pegs/controls
« Reply #2 on: August 27, 2012, 08:46:00 pm »
Thanks for the response.
08 Bullet ES (AVL)
AgentX
Re: Pegs/controls
« Reply #3 on: August 28, 2012, 11:53:52 pm »
No worries--for what it's worth, my folding rear-sets never scrape like the stock pegs did.
ridgerunner
Re: Pegs/controls
« Reply #4 on: August 29, 2012, 12:27:20 am »
I may just modify the ones I have. The left peg sticks much farther out than the right one. I could just cut down the spacer and go with it. Floorboards are just more comfortable. I had them on my old Harley touring bike and an old Kawi KZ1000P. That and higher bars and the ol' Bullet would be much more comfy.
08 Bullet ES (AVL)
The_Rigger
Re: Pegs/controls
« Reply #5 on: August 02, 2013, 03:28:14 pm »
I'd love to find a set of boards to put on Fiona, to keep the heel of my right boot from melting on the exhaust pipe.  Has anyone adapted a set of boards to a US-spec C5 successfully?  Resoling Doc Martens is bloody expensive...
-Dave
2012 C5 Special
