I've read a bit about Dyna beads and tire balancing and thought I'd give them a try. Cost about $28 including postage from the USA to Australia.
Kit included Dyna beads - plastic hose and puffer style plastic bottle.
Recommended weight of Dyna beads per wheel was 2oz. Naturally you get 2 x 2oz packets
Close up of the micro beads. That's one 2oz packet.
Once I had spooned all the beads into the bottle ( best way to get them in ) it was just a matter of turning the wheel/tire valve to the 6 o clock position then slip the small plastic tube to the valve.
To get the beads free flowing - I gently tapped the top side of the plastic bottle. Don't be aggressive with this task or they will completely block the valve up and you will have to remove the tube and start all over again.
Took about 2 minutes per wheel plus the extra time to reinstall the valve and foot pump the tires to correct pressure.
Unfortunately that's as far as i got and it started to rain. Although I would have like to give it a quick run I'd just finished the bleed job on the front disc so would prefer to risk it on a dry track.
Good weather predicted tomorrow so hopefully to continue on with a test ride and evaluation on the product............or should the member's give it a go.
Stay tuned and time will tell.
