Not that 'oil leaks' are a new topic here, but I didn't find anything that addressed specifically what I think I have.
After some testing. I have determined that my 2012 C5 is leaking oil past the kick start lever cover, (not the kick start shaft seal itself). After thoroughly cleaning that area and observing that overnight, oil reappears at the bottom edge of this cover. Engine doesn't need to run, it just shows up. It is not tracking down from anywhere else on the engine.
I have both the factory shop manual and the factory parts manual, so I think I am about to tackle this job myself. I know there must be a few of you out there that have removed the RH side engine cover - anything I should be aware of? I'm not sure what I'll find, but this cover has to be removed to gain full access to the 4 very small Allen bolts that secure the kick start lever cover. (The three bolts I could access were tight), but looking at the schematic, there doesn't appear to be a gasket of any kind under this cover. I plan on making a gasket, or using some type of 'gasket making' sealer before reassembling.
Anyone have a similar situation? Any/all comments welcome!
