08' Thruxton, bit of a 66' TR6 and Liam the shop dog
May 05, 2016, 11:12:58 am
Author Topic: jettin bar end weights  (Read 3298 times)
wildbill
« on: August 21, 2012, 06:12:30 am »
I've been complaining for a while now about the severe handle bar vibration on my bike. Scott mentioned about gel grips and jettin bar end weights.
so i decided to give it a try and go for the bar end weights. i chose the extra heavy version at 15oz per side.
the fit was a straight foreward affair and a direct fit. the Allen screw had to be replaced by one a few millimetres longer.
took the bike out today on a 120 kl run and was surprised how well it knocked back the handle bar vibration.
although not totally eliminated it did drop the high pitch handle bar resonance to an acceptable level.
prior to the install i have never cruised at 100 kph for more than one or two kl without severe tingling/buzzing in the finger tips.
to my surprise today i sat on this 100 kph cruise for a good 20 kl.arriving at the half way mark i pulled over and swapped back to the original bar end weights.
 back on the bike i noticed the annoying raspy vibe immediately. about 3 kl up the road i pulled over and re -fitted the jettin bar weight.
once again big difference and this time feeling more confident i took it to 120kph with good road feel and a lot less vibes. also noted i could see clearly out of both mirrors.
although where pretty good in the land of oz - not at the one time though :D
are they any good. my opinion yes. my handle bar vibration was very bad and this mod knocked quite a bit of the shakes out of it.
on a bike with just a bit of vibration it could do wonders.
will throw in a few photos tomorrow.
2011 C5 black/chrome
2012 C5 maroon/chrome
2013 B5 black
2014 Continental gt
2014 C5 tan
2015 black/chrome
2015 limited edition dispatch
2016 lagoon blue
2004 mazda-speed miata
2001 bmw z3
Fogrunner
Re: jettin bar end weights
« Reply #1 on: August 21, 2012, 07:29:48 am »
Good to know!! And the change back check confirms they do work.
Thanks for the info.
Phil
2012 G5 Classic
wildbill
« Reply #2 on: August 21, 2012, 08:35:29 am »
best of all they are pretty cheap to buy at around the $35 mark.
for cosmetic value the only thing required to do is to drill open the outside centre of the bar end to allow the Allen bolt to seat  flush with the case
2013 B5 black
2014 Continental gt
2014 C5 tan
2015 black/chrome
2016 lagoon blue
2001 bmw z3
ADB
« Reply #3 on: August 21, 2012, 08:36:39 am »
I can second that...I installed the same weights last weekend and experienced the same results. I was plesently surprised at how well they did to fix the vibrations.
Tri750
  • Big Al
« Reply #4 on: August 21, 2012, 08:40:17 am »
Be sure to use your loctite (blue) on the center bolts.
Current bikes:
'71 BMW R75/5 racer
'73 Kaw Z1 racer
'77 Tri 750 Bonneville
'99 BMW R1100RT
« Reply #5 on: August 21, 2012, 12:01:56 pm »
+1 to that!
I'm glad these worked so well for you.  The high frequency vibes are what really get to you and the more the bars weigh the lower their resonant frequency.
I also like that these weights allow for either easy mounting of CRG type mirrors or can be used as a tie down point.
TWinOKC
« Reply #6 on: August 21, 2012, 12:29:04 pm »
Could someone be so kind as to post a link to the jettin bar end weights?
I did a search and didn't have any luck.
2010  C5  Teal
2011 Triumph Bonneville T100
2015 Scrambler Ducati
« Reply #7 on: August 21, 2012, 12:50:04 pm »
http://www.jettin.com/barends.html
Go for the heavy steel models.
The_Rigger
« Reply #8 on: August 21, 2012, 03:34:26 pm »
I'm gonna try them, too. Let's see how annoying it'll be adapting the Halcyon mirror brackets to these suckers; I may need weight screws 6" long eventually...
If the Jettins aren't heavy enough for you, one of the Vespa forums had a listing for some 17-oz.(!!!) bar-end weights from Manic Salamander.
http://www.manicsalamander.com/products/details-of-weights.aspx
« Last Edit: August 21, 2012, 05:15:40 pm by The_Rigger »
-Dave
2012 C5 Special
« Reply #9 on: August 21, 2012, 04:21:28 pm »
Those are great too but they start getting really long.
wildbill
« Reply #10 on: August 22, 2012, 09:32:37 am »
on the bike photo of bar weight. all i need now is to recess the bolt into the case.
2013 B5 black
2014 Continental gt
2014 C5 tan
2015 black/chrome
2016 lagoon blue
2001 bmw z3
re:RE
« Reply #11 on: August 22, 2012, 08:27:29 pm »
I ordered the Kuryakyn gel grips, end weights and Contoured Throttle Boss.  I haven't installed them yet, but will soon.  I'll report back on any improvements they provide.
2012.5 (19" Wheel) C5 Desert Storm
Bulletman
  • 2011 - C5 Classic Black
« Reply #12 on: August 23, 2012, 03:54:56 pm »
Al do you know where I could buy longer hex center bolts, so I coud do this and also not have any issues with my Napoleans?
Mark
"A Blast from my Past"
Mark F   (Northern, CA)
Black C5 2011
Bulletman
« Reply #13 on: August 23, 2012, 04:00:49 pm »
Was wondering if these jettin bar end weights will affect the installation of Napolean bar end Mirrors?
Black C5 2011
« Reply #14 on: August 23, 2012, 04:01:27 pm »
Just about any hardware store, or Home Depot.
How will they affect the Napolean mountings? You may need slightly long bolts, otherwise, it looks like a slip on deal.
« Last Edit: August 23, 2012, 04:04:25 pm by barenekd »
